METRIC SYSTEM
johndiesel
METRIC SYSTEM
I am in Australia and we use the metric system.
Is the Trinity configured so that it can be set up to give metric readings
will need this for virtual drag tree and gauge monitor.
RE: METRIC SYSTEM
All gauges in Trinity can be converted to C from F or KPH from MPH through the logging menu by selecting convert units.
RE: METRIC SYSTEM
right on the main screen of the trinity... lower right... says "Logging"
heh...
heh...
RE: METRIC SYSTEM
ok i find the logging but there is add gages and remove it where is convert units.
RE: METRIC SYSTEM
Add a guage for the desired parameter (e.g. Vehichle speed); Then select the actual gauge and "Change Display Units" is available.
EssentialJuice
RE: METRIC SYSTEM
can you change from metric to standard for gauge readings? such as synth gauges and others?
2004 f350ps
4" tb cat delete
4" tb cat delete
RE: METRIC SYSTEM
Yes, select the gauge on the logging screen and hit change units.
EssentialJuice
RE: METRIC SYSTEM
are we both talking about the trinity monitoring screen? like the synth on monitoring screen is boost kPa. can it be changed to psi?
thank you.
thank you.
2004 f350ps
4" tb cat delete
4" tb cat delete
RE: METRIC SYSTEM
yes, it can.
RE: METRIC SYSTEM
Being in the UK we use metric and imperial lol.
Any temp gauge defaults to deg F and I like to work in Deg C easy to change over. edit gauge and change units. Simples.
