2005 Dodge 2500 Cummins Diesel Questions
Posted: Mon Jul 20, 2009 11:09 pm
A few questions:
1. When do you think the Tire Size Adjustment will be added. I was a little disappointed that it doesn't work with the '04 & '05. Without being able to adjust tire size everything is out of whack.
2. I'm in Canada and we use the metric system so it would be nice to have the option to use it. I have a MPG gauge built into the truck and it's about 5 mpg too high using the Performance Tune. It was only off by .5 mpg before so I expect the difference between an Imperial gallon and US gallon is having some effect on the gauge. The good news is that I am getting a true 25 mpg. result on the highway, 2 mpg better than stock!
3. On the Performance Tune, when you gently rev the motor up at idle the idle speed "hangs" slightly before dropping back to normal idle speed. Is this normal? It doesn't do it with the stock settings.
4. When you try and set up custom gauges, one gauge overlaps another one slightly...how can you move it from blocking it?
