pinging >>>>>> with diablo > &g
fadhil
Post by fadhil »
I have gmc Yukon 6.2l there are pinging sound come from the engine after I using the Diablo tuning and also after the adjusting
When I return the factor tuning there no pinging the pinging sound come after I crocus 5000 rpm with Diablo tuning but the factor tuning there are ok
Can you help me what I need to adjust
Solid
RE: pinging >>>>>> with diablo >
Post by Solid »
Well i know that you have to be doing this http://www.diablosport.com/index.php?na ... opic&t=917 if you want if you want it gone. But i don't know if this helps. I'm sure someone will tune in to give you the best advice. But I think logging should do it.
CANUCKPREDATOR
Post by CANUCKPREDATOR »
this was discussed before, IF you have pinging you will see TSKR when you monitor your motor. So do some logging like the link about says and lets see if you REALLY have pinging. Post you log here so we can have a look.
05Z71
Post by 05Z71 »
What tune are you running, and what octane and brand fuel are you using?
Makin friends one post at a time!
05 Chevy Z71 5.3L, 18x9 KMC XD Spy Wheels, 275/70R18 Cooper Zeon LTZ, Cherry Bomb Exhaust, K&N Drop in, Predator TWEAKED
CANUCKPREDATOR
he's in UAE, running about equivalent of 92 octane in a 6L. This was discussed before with no results because we didn't see a log.
Grumpy_Aero_Guy
Post by Grumpy_Aero_Guy »
yeah, a log would definately help here...
DSLogRedux.com
dxb_escalade
Re: RE: pinging >>>>>> with diablo &
Post by dxb_escalade »
CANUCKPREDATOR wrote:he's in UAE, running about equivalent of 92 octane in a 6L. This was discussed before with no results because we didn't see a log.
for ur info we don't have 92 octane we have 95 and 98
http://www.emarat.ae/service/fuel.php
K&N CAI, Custom DiabLew Tune
05Z71
RE: Re: RE: pinging >>>>>> with diablo
Post by 05Z71 »
For your info, your 95 and 98 are like our 89 and 92. Just saying...
uky2000
Re: RE: Re: RE: pinging >>>>>> with dia
Post by uky2000 »
05Z71 wrote:For your info, your 95 and 98 are like our 89 and 92. Just saying...
Proved to me
yukon denali 6.2 with k&n air intake sys+corsa exhaust sys+diablo tune
08 Corvette zo6 with k&n cai+corsa exhaust sys+diablo tune
09 mustang gt waiting for predator
05 mustang gt with P-1SC-1 procharger
CANUCKPREDATOR
RE: Re: RE: Re: RE: pinging >>>>>> with
Exerpt taken from Google Answers:
"In the United States, pump octane is an average of 2 ratings, research octane (RON) and motor octane (MON). If you look at any gas pump in the United States, you will see a yellow sticker that says "octane by R + M / 2" That is the basic formula for an average. These 2 numbers mean different things. You could make an analogy to that of a blood pressure reading (systolic and diastolic). Research Octane number is always higher than Motor Octane number.
In Europe, they only report the RON. You may hear people discussing that in Europe, the octane is higher. Well, that is not exactly true. You see, in Europe, you might find 96 octane at a local gas station. (wow 96, highest we have here is 94). Well, that 96 is equivalent to 92 here in the States."
05Z71
Post by 05Z71 »
I make the shit you tard! Is that proof enough?
uky2000
Re: RE: Re: RE: Re: RE: pinging >>>>>>
Post by uky2000 »
CANUCKPREDATOR wrote:Exerpt taken from Google Answers:
thanks for ur explanation
i may be wrong but i bought my z06 from the state and i installed the performance tune over there with 92octane my car was runing good for 6 months then i sent it to dubai and i tried 98 octane on my car i noticed big change in the performance even on the dyno
CANUCK thanks to u again
dxb_escalade
RE: Re: RE: Re: RE: Re: RE: pinging >>>>>&g
uky2000 u r 100% correct
canuck good info
05Z71 i will proof it for u
1- our 6.2 escalade 441 hp http://www.cadillacarabia.com/content_d ... specs.html
2- us 6.2 escalade 403 hp http://www.cadillac.com/cadillacjsp/mod ... Powertrain
u know why
this info from wikipedia
The 2007 Cadillac Escalade has a 6.2 L Vortec 6200 (RPO L92) (≈376 cu in) engine. It is an all-aluminum design which, while still a pushrod engine, boasts variable valve timing, a first in a mass-produced non-overhead cam V8 engine. The system adjusts both intake and exhaust timing between two settings. This engine produces 402 hp (301 kW) and 417 ft·lb (565 N·m) in the GMC Yukon Denali/XL Denali, Sierra SLT, and in the GMC Sierra Denali, and rated at 403 hp (301 kW) and 415 ft·lbf (563 N·m) (441hp with 95 octane export version) in the Hummer and in the Cadillac Escalade. It is also available in the Chevrolet Tahoe LTZ, with power ratings of 395 hp (295 kW) and 417 ft·lbf (565 N·m).
http://en.wikipedia.org/wiki/GM_Vortec_engine
Solid
RE: Re: RE: Re: RE: Re: RE: pinging >>>>>&a
Post by Solid »
Hello Dxb,
It's not really all because of the gas octane. If i'm correct the americans have an other messuring about the HP then they have here in europe. Ã
Grumpy_Aero_Guy
it is safe to divide DIN horsepower by 1.0139 to arrive at SAE net hp
DSLogRedux.com
