Trans shift 02' PSD
Posted: Wed Jul 29, 2009 8:53 pm
by msc42783
02' f250 U7170. I plugged in the formula you gave me to adjust the trans shift point. Rev/mile = tire size. So my formula came out to be Nov=(582*3.73)/60 which =36.18. I plugged this into the base nov setting on the modify section of the programmer and the shifting was pretty bad, is this right? I put it back to the previous setting which is better, but still not where I want it. When I drive normal it shifts okay, but when I get in the gas just a little or when I give it gas to go up a hill it shifts into higher gears to fast. I am running 325/65/18 tires with a 3.73 gear and an automatic trans. I just want to program the tire difference in to make it shift better. Thanks.
RE: Trans shift 02
Posted: Wed Jul 29, 2009 9:23 pm
by SCGt94
post up the tire specs on here and let me give it a go
RE: Trans shift 02
Posted: Thu Jul 30, 2009 7:48 pm
by msc42783
325/65/18
RE: Trans shift 02
Posted: Thu Jul 30, 2009 11:59 pm
by SCGt94
since every tire tends to be different, revs per mile might change. Try the manufactures website or tirerack.com. What brand of tires are they make/model? I got 599 for revs per mile for a similar sized tire but no guarantee that that is correct.
RE: Trans shift 02
Posted: Fri Jul 31, 2009 10:25 pm
by msc42783
they are 325/65/18 toyo open country a/t's
RE: Trans shift 02
Posted: Mon Aug 03, 2009 12:43 pm
by SCGt94
i got 35.882
