94 mustang using powertrain limiting as 2 step
trying to use the powertrain limiting as 2 step I can get limiter to work but wont shut off or disable this is a manual trans car is there a way to make this work?
RE: 94 mustang using powertrain limiting as 2 step
Not sure it can be done on the older cars, but did you set the MPH to disable to .5 MPH?
Try using the wizard to set it up?
