Can a I use my Z06's Preditor on my Viper?
EbbyEsq
Post by EbbyEsq »
This may be a stupid question but I have to ask it. I have an 03 Z06 and an 05 Viper. My Preditor is for my Z06 but I noticed that it plugs up to the Viper as well. I want to know whether there's anyway I can use the tuner to adjust the cooling fans on the Viper? Is there a program I can download or anything like that?
AUcummins
RE: Can a I use my Z06
Post by AUcummins »
One of the main guys will chime in, but I seriously doubt that you can use the Predator for your Z06 to change settings in your Viper. They both utilize the same OBD-II connection but have totally different programs and ECU's. You will most likely need to buy a tuner for the Viper as well, if they make one. :?:
'06 2500 CTD 4x4 Sport, Predator/Puck Stack, Boost Fooler, aFe Stage 2, Banks Duals, IssPro Gauges, 5" Lift w/ Fox Shox, 325/65/18 Terra Grapplers on 18x9 Moto Metals, Bushwacker Color Matched Flares, Rumble-Bee Scoop, and lots more.......
johan
Post by johan »
The diagnostics ports where standardized around 1986-7 when obd-II came out so the ports will all be the same, but the protocol the Viper uses is very different from the vette so it will not work on the viper.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
