Page 1 of 2
Ported throttle body for 5.3?
Posted: Thu Aug 06, 2009 4:03 pm
by SandMan817
I was looking around on ebay and i found a company that sells a ported throttle body for the 5.3, i was just wondering if anyone has used one of these before, and if so, did you notice anything? Also, would the ported TB mess with adjusting the LTFT's?
RE: Ported throttle body for 5.3?
Posted: Thu Aug 06, 2009 4:19 pm
by Scooter88
Hey sandman if you find anythin out post up cause im definitely interested to!!
Posted: Thu Aug 06, 2009 4:23 pm
It will likely affect your LTFTs, they are generally worth about 5-8 rwhp on a stock LS1, I would guess even less on a 5.3...
Posted: Thu Aug 06, 2009 4:34 pm
by SandMan817
i've been looking around and people have said that they notice a nice improvement in the mid to high rpm range, and they are good for about 10-15ft/lb and around that 5-8hp gain. Would these gains be higher after adjusting the LFTS's and the Power Enrichment?
Posted: Thu Aug 06, 2009 10:08 pm
by 05Z71
TB spacer FTW?
Posted: Thu Aug 06, 2009 11:33 pm
by SandMan817
a ported throttle body....
Posted: Thu Aug 06, 2009 11:59 pm
by 05Z71
Meh, I wouldn't waste the money like you did with that TB spacer if I was you. You will only see a 5 hp gain if that, and that is at the flywheel. So basically RWHP you are looking at a <3 hp gain. I don't know what you are paying for the new TB but from the ones I have seen, they are all around $100 shipped. So with that said, you are essentially paying $33 per hp which is entirely too high for a simple bolt on. The stock TBs are good enough for a NA vehicle. When you get into the forced induction, that is when the ported and polished TB starts being very effective. Just my 2 cents on it, but heck what do I know? :twisted:
Posted: Thu Aug 13, 2009 6:24 pm
by rletzgus
Haad one. what a waste. It was more problem than it was worth. It did give me more low end torque, but couldn't stop the trouble codes.
Posted: Fri Aug 14, 2009 5:37 am
by SandMan817
do you remember what codes you were getting?
Posted: Fri Aug 21, 2009 11:23 pm
by 05Z71
I think it was the P0654 code....."YOU WASTED YOUR MONEY" code...
Posted: Sat Aug 22, 2009 5:01 am
by SandMan817
haha aight man, even on a truck with LT's, high flow cats, xpipe, intake, and cam?
Posted: Sat Aug 22, 2009 9:51 pm
by 05Z71
Most definitely! They are NO GOOD!!! If you don't believe me then go spend $100 and get one. I will accept your apology later when you come back and say you are sorry and should have listened to me. :punisher:
Posted: Sun Aug 23, 2009 1:43 am
by SandMan817
haha i got you man, i believe you! Im sure at some point you would need to replace your throttle body.
Posted: Sun Aug 23, 2009 4:29 am
by 05Z71
Yeah, after you get to about 500+ hp
Posted: Thu Sep 03, 2009 7:20 pm
by lt1z350
i ported mine myself and noticed a seat of the pants difference. throttle response is way better and off the line power is slightly better. I have a 2007 with the larger 90mm tb and on my 2003 I had one and didnt see quite as much as I have on my 2007. I have a smaller tb that i ported the same way as my 2007 one and it is the one with the electronic sensor on it I will sell cheap if anyone wants it.
