SRT Engineers admit car has hesitation - can Diablo fix it?
During the last SRT Engineers chat, the SRT Engineers said this about the car's hesitation.
http://www.lxforums.com/board/showpost. ... stcount=87
Question
Why does this vehicle have so much hesitation when you step on the gas pedal? seems like it winds up and then shoots out. It feels like it builds up power, then releases it.
SRT Engineer's Answer
Your feeling what the government has forced us to do for emissions regulations. We don't like it either! Its related to the pedal/throttle relationship and combustion stability.
Can Diablo reverse engineer out this "pedal/throttle relationship and combustion stability" so we have better throttle response?
Question
2005 300C
RE: SRT Engineers admit car has hesitation - can Diablo fix
I installed an 85mm throttle body on my R/T and it eliminated this problem altogether. The throttle response is smooth at all rpm's now with no hesitation.
Have you tried the Predator tunes?
Throttle response is increased quite a bit, and can be increased more in a custom tune if desired.
Re: RE: SRT Engineers admit car has hesitation - can Diablo
Sure. Running 91 oct tune. Is the Diablo throttle response adjustment the same as adjusting tip-in?mikel wrote:Have you tried the Predator tunes?
There seems to be several different definitions of throttle hesitation.
My biggest beaf with our car is the RPM bogging during moderate acceleration.
Here is a log of the bogging. As I am increasing pedal pressure to moderatly accelerate, the RPMs decrease when they should be increasing.
This creates a bogging/hesitation. The green RPM line makes a U-turn south when it should be headed north with the red Pdl Percent line.
This is with the Predator 91 tune. The bogging occurs less often with the Predator, but the Predator has not fixed it, as shown in this log.
I don't know if the bogging in this log is the same thing the SRT Engineers were referring to. If not, then our cars have more than one problem with bogging/hesitation.
2005 300C
Hi JackFlash, I am considering getting a 85mm TB for my car. Can you tell me what all you had to do. Did you have to take it to the dealer? What brand did you get? Have you discovered any down side from making the change?JackFlash wrote:I installed an 85mm throttle body on my R/T and it eliminated this problem altogether. The throttle response is smooth at all rpm's now with no hesitation.
"El Magnifico" 2009 Challenger SRT8 AutoStick, Corsa Sport Catback Exhaust, Trinity 91 Modified Tune, 180 T-stat, Moroso Catch Can, DMH Electronic Cut Outs, ProTorque Billet Stator 3200 RPM High Stall Torque Converter, K&N, BFG 295/40/20w Rear Tires
Cruisin1966
We just installed an Arrington 85 mm TB in my buddy's 09 SuperBee last night. Can't imagine it's much different than just pulling off the air intake tube, unbolting the old TB, and bolting in the new TB and re-installing the intake tube.broadfca wrote:Hi JackFlash, I am considering getting a 85mm TB for my car. Can you tell me what all you had to do. Did you have to take it to the dealer? What brand did you get? Have you discovered any down side from making the change?JackFlash wrote:I installed an 85mm throttle body on my R/T and it eliminated this problem altogether. The throttle response is smooth at all rpm's now with no hesitation.
2007 Sublime Daytona #082/150
McKinney catch can (to be installed)
TRippgoodman
2009 Challenger SRT How to turn off ESP?
I have a 2009 Challenger SRT8 That I just installed a Vortech Supercharger kit on. It was programed with a Predator #VR7135 Serial#249872 that came with the kit. The problem is that the ESP throttles back almost everytime you give it the gas. Vortech tells me that I should contact Diablo to see if they can turn off the ESP. Any help is appreciated. Trippgoodman
I would not want to turn off the ESP or the ABS permanently, But to make a clean run down the drag strip to see what the car could do would be nice option once or twice a year. Please help. Thanks, Trippgoodman
RE: 2009 Challenger SRT How to turn off ESP?
Do you not have a quick adjust parameter to disable ESP?
Thats not really something we recommend for daily driving anyhow, as it disables ABS as well.
You're supposed to have the blade calibrated with the StarScan. Alot of us haven't bothered though, myself included.Cruisin1966 wrote: We just installed an Arrington 85 mm TB in my buddy's 09 SuperBee last night. Can't imagine it's much different than just pulling off the air intake tube, unbolting the old TB, and bolting in the new TB and re-installing the intake tube.
I used the modern muscle 85mm TB. It works great. Billet Tech will port the one you have on the car, if you send it to them, but then the car will be down a while. It is a well worth mod in my book. Made a big difference, my car really liked it, but I don’t think you gain much hp, just drivability. It eliminated all the hesitation, dead spots, and made accelerating very smooth. They are really easy to put on. It takes at the most ½ hour.broadfca wrote:Hi JackFlash, I am considering getting a 85mm TB for my car. Can you tell me what all you had to do. Did you have to take it to the dealer? What brand did you get? Have you discovered any down side from making the change?JackFlash wrote:I installed an 85mm throttle body on my R/T and it eliminated this problem altogether. The throttle response is smooth at all rpm's now with no hesitation.
You can either take it to the dealer and have it calibrated (not really necessary), or turn the key on (don’t start the car), depress the throttle slowly and let it back up slowly, then turn key off. This is said to calibrate the plates as well. In the “easter eggâ€
I used the modern muscle 85mm TB. It works great. Billet Tech will port the one you have on the car, if you send it to them, but then the car will be down a while. It is a well worth mod in my book. Made a big difference, my car really liked it, but I don’t think you gain much hp, just drivability. It eliminated all the hesitation, dead spots, and made accelerating very smooth. They are really easy to put on. It takes at the most ½ hour.JackFlash wrote:broadfca wrote:Hi JackFlash, I am considering getting a 85mm TB for my car. Can you tell me what all you had to do. Did you have to take it to the dealer? What brand did you get? Have you discovered any down side from making the change?JackFlash wrote:I installed an 85mm throttle body on my R/T and it eliminated this problem altogether. The throttle response is smooth at all rpm's now with no hesitation.
What are the results of installing the Arrington TB? Did it eliminate the bogging and dead spots on acceleration?Cruisin1966 wrote:We just installed an Arrington 85 mm TB in my buddy's 09 SuperBee last night. Can't imagine it's much different than just pulling off the air intake tube, unbolting the old TB, and bolting in the new TB and re-installing the intake tube.broadfca wrote:Hi JackFlash, I am considering getting a 85mm TB for my car. Can you tell me what all you had to do. Did you have to take it to the dealer? What brand did you get? Have you discovered any down side from making the change?JackFlash wrote:I installed an 85mm throttle body on my R/T and it eliminated this problem altogether. The throttle response is smooth at all rpm's now with no hesitation.
Cruisin1966
So far so good. His car never bogged down as much as mine, but he seems quite pleased with the performance of the car with the TB. He's still data logging a little to see if there are any differences between now and before.broadfca wrote:
Any update on the new TB? I'm very curious because if the new TB has helped with the bogging and hesitation, then I'm going to get one right away.Cruisin1966 wrote:So far so good. His car never bogged down as much as mine, but he seems quite pleased with the performance of the car with the TB. He's still data logging a little to see if there are any differences between now and before.broadfca wrote:
RE: Re: RE: SRT Engineers admit car has hesitation - can Dia
BROADFCA, Have you tried to calibrate your throttle?
Turn key on, press slowly and hold down pedal for a few secs, slowly release and repeat then try it, it has helped me.
