Hello, I'm considering purchasing a u7194 for my 2007 avalanche 5.3(vin#3)
from reading through the posts on here I see that there are no user options in it yet to disable tourque management but I do have a couple questions about the tunes.
do they do the following things I'm looking for.
1)reduce the Power Enrichment delay( time it akes to go from closed to open loop on a WOT start) from the stock 4 seconds to 0
2) remove abuse mode from the torque management
3) reduce all other TM by at least 50% or more
4)reduce the shift lag on the 1-2 shift
5) raise the shift points and shift firmness
6)remove the top speed limiter.
thanks
Derek ......
u7194 questions (for 2007 avalanche)
RE: u7194 questions (for 2007 avalanche)
I don't believe there is tranny support for that model yet (just like mine
), so none of the shifting or tranny TM will be addressed right now. But it does remove some of the engine TM, speed limiter, and reduces the PE delay.
Re: u7194 questions (for 2007 avalanche)
1.Yesdjerome wrote:Hello, I'm considering purchasing a u7194 for my 2007 avalanche 5.3(vin#3)
thanks
Derek ......
2.Just enough to keep it out of your way
3."
4.No shifting changes are made, but the reduced TM will provide better shift feel/performance.
5.Not yet, coming in the future
6.Yes
