2005 Dodge ram - High EGT's when using tow tune
Canuckbuzz
Post by Canuckbuzz »
Hey all
Just installed the diable sport tow tune into my dad's '05 along with a set of guages.
Admitedly we did not run the guaes without the tune first - but now with the tune and towing ihs 5thwheel - the EGT's were very high - over 1400
Does this seem right? I thought the Tow tune was designed to be ok for towing?
RRAM
RE: 2005 Dodge ram - High EGT
Post by RRAM »
I am assuming your getting those numbers when pulling it up hill or getting up to speed. How big is the trailer? I seen lots of 1400 and 1500+ when pulling my trailer through the BC mountains. I just had to learn how drive it. I was on perf tune. I kept it in tow haul mode and if my egts got high I would floor it quickly and it would shift to D and lockup and egts would come down. I find its really a matter of the right foot.
That said I planning on adding a water meth system so then I can drive like I want to without so much worry.
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
kw5.9
Post by kw5.9 »
on tow tune i can hiy 1400* with just a hard pull to get up to speed (35mph-95mph)...2x on the water meth.
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
ropnjessi
Post by ropnjessi »
Canuckbuzz wrote:Hey all
So where is the EGT probe located post or pre turbo?
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
Dodgezilla
Post by Dodgezilla »
Those are normal EGTs for a 600 series engine. Do you guys have a better intake and exhaust on the truck yet?
I bet that if you installed the stock tune back in it will still have temps that high.
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
concoursd
Post by concoursd »
run a baseline first which means pull the trailer in stock mode. Then when tuning is installed, do not exceed 150 degrees over the stock peak value.
Canuckbuzz
Thanks for the replies all.
Pyro is pre turbo in the manifold. He has CAI and turbo back exhaust system.
Trailer is a 36" 5th wheel.
I guess he got the 1400-1500 when going up a long hill. He uninstalled the tune - and was still able to hit 1400 - just took a litle longer.
I gave him some of you suggestions - and he he's reinstalled the tow tune - but has learned he doesnt need to floor it anymore going up hills and egt's have been decent for him
Thanks for the help all
Dodgezilla
If it's an auto then have him hit the T/H button when he's pulling a big hill, That should drop the temps a bit. If it's a manual then tell him to downshift a gear on those big hills....
