Error Codes 1000 & 2290
MACHISE
Post by MACHISE »
I have a 2007 F250 and ever since I have used the predator in it the two codes show up every time I get on it hard. the new revision r8 17 is smoother and maybe a little stronger but I still get the codes . I never had this problem with my 05. the 07turbo will only pull about 23 ft lbs in the 100 hp tune my 05 would pull near the red line. on the stock tune and the 60 hp tune the turbo will go near 30 I would just run the 60 hp tune but the fuel economy is better in the 100 hp.. What can I do about this problem??
Mac[/code]
willie
RE: Error Codes 1000 & 2290
Post by willie »
Hello , thanks for bringing that up to us, i thougth we corrected the problem, the P1000 is present because of the flash to the PCM and probably will go away in a few KEY cycles, P2290 is ICP pressure to low and the new revision was aim to corected that problem with the new tunes and i did 2 days off road testing for fuel economy with the bew tunes and had no SES, what i can do for you is a CUSTOM tune to eliminate the problem and to see if is spesific to one CALIBRATION so we can REDO a new CROWN contact our TECH DEPARTMENT at 561-908-0040 X1 so we can help you....
Return to “Predator Ford Gas”
