2005 srt-4. P2074 trouble code
Posted: Sun Aug 16, 2009 5:57 pm
by Extreme_srt-4
Trinity-6jrt949-1
1r04
2005 srt-4
Haveing non stop problems with the ecu code
p2074 turn it off comes right back
pleas help me !!!!!!!!!!
RE: 2005 srt-4. P2074 trouble code
Posted: Sun Aug 16, 2009 6:16 pm
by Mike_Levy
Thats an Intake Manifold Tuning Valve code. Since it comes back, I'd bet theres actually something wrong with the valve.
Posted: Sun Aug 16, 2009 6:40 pm
by Extreme_srt-4
It does not come on at idle only when half throttle or part thottle
runes good at wot. It all starded when I put the thrttole body on ???
Posted: Sun Aug 16, 2009 7:09 pm
by Mike_Levy
Is the SRT4 Drive By Wire? Probably needs to be calibrated if it is.
Posted: Sun Aug 16, 2009 7:28 pm
by Extreme_srt-4
I don't think it is drive by wire it has a cable to the thottle body
Re: RE: 2005 srt-4. P2074 trouble code
Posted: Sun Aug 16, 2009 8:41 pm
by duster360
Mike_Levy wrote:Thats an Intake Manifold Tuning Valve code. Since it comes back, I'd bet theres actually something wrong with the valve.......Is the SRT4 Drive By Wire? Probably needs to be calibrated if it is.
Stick to newb Hemi questions mike.
1) SRT-4 do not have a Manifold Tune valve
2) SRT-4 have a throttle cable.
3) On a SRT-4, P2074 is for MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION- HIGH FLOW/VACUUM LEAK
its a not too uncommon code with aftermarket wga and bov, especially with 2005s. There's actually a Factory TSB for this code for 2005s.
http://www.ertyu.org/steven_nikkel/neon ... 042-04.pdf
PCM boost control and a properly scaled Wastegate Duty cycle table to match your uber stiff wga, this code isn't much of an issue.
imo stiff wga aren't worth the trouble over the stock wga if you have a stock turbo.
If it all started with the TB, your TPS voltage may be off
Posted: Sun Aug 16, 2009 8:51 pm
by Mike_Levy
duster360 wrote:Stick to newb Hemi questions mike.
I'm reading straight from the Dodge Codes thread. Thats where my info came from.
Thats also why I asked if it was DBW.
RE: Re: RE: 2005 srt-4. P2074 trouble code
Posted: Mon Aug 17, 2009 9:16 am
by NickLovin
I've been begging DS to find the switch that disables this code as it is a major issue. The stage cals already have this diagnostic feature disabled so if you continue to have problems I suggest upgrading to a S2 PCM.
Posted: Mon Aug 17, 2009 9:06 pm
by Extreme_srt-4
Thanks going to s2 PCM hope it works
