6.ol 9r10 hiccups
bdog1
6.ol 9r10 hiccups
Post by bdog1 »
Hey Guys,
Had some recent work done on an '03 crew cab. Tech updated it to VXAP2N2.
Had to load the 9r10 to recognize. The 100hp makes it feel like it's missing. Sometimes when it fires up a puff of white comes out and idles erraticly. If you give it throttle it just "loads up" and no revs.
60 hp feels alright but not as much power as previous tune.
Any insight....is it an injector problem?
Cheers,
B
SCGt94
RE: 6.ol 9r10 hiccups
Post by SCGt94 »
white smoke screams injector problem all over it from what i've seen. Getting any trouble codes?
Don
2002 WS6
bdog1
Post by bdog1 »
Just a couple to do with glow plug no. 7 and the p1000 . I'll check again tonight. I only ran the 100hp for a short trip around town.
Been running the tow tune for last few days with a 9000lb boat behind it. Runs fine but starts up with a funny idle is the best i can describe it. At this point i think i better go back to stock.
tuningss
Post by tuningss »
Could be the egr cooler also.
http://www.tpctuning.com
bdog1
Post by bdog1 »
Now that i think about it, the puff only came because i started it and it idled erratically so i immediately shut it off. Upon restart it puffed white, in my opinion because it was loaded with diesel.
bdog1
Post by bdog1 »
Is anyone else having issues with this cal id and the new revision? I went back to stock but it's so damn boring to drive.
smorrisii
same issues
Post by smorrisii »
I am having the exact same issues, same calid ,same revision . truck ran great before, did not have a programmer before the 9r10 update so I can only compare to stock.
concoursd
RE: same issues
Post by concoursd »
white smoke to me would indicate coolant, black smoke would indicate rich fuel mixture. I could be wrong though.
SCGt94
RE: same issues
Post by SCGt94 »
Does the 60hp do similar things at start up etc..?
Don
2002 WS6
SCGt94
RE: same issues
Post by SCGt94 »
I believe I have a fix for this, providing i get some more feedback. I need some more testers. I had a guy with similar issues send me and email and he said its working great now so I believe i got it down. Hit me up with an email and an ori and i will take care of you guys, then ill release a new crom with the fix.
Don
2002 WS6
bdog1
RE: same issues
Post by bdog1 »
Just the 100 hp setting causes the rough start/idle. Thanks Don!
smorrisii
6.0 rough cold start.
Post by smorrisii »
Hold the phone on that fix, Don ! The truck started up fine two times, and then went to acting crazy again. I want to evaluate it a little longer to eliminate everythiing else. I want to try some more "true cold starts" because Im not sure the glow plug circuit is even working and Iwant to make sure it's not hardware related on my end. Thanks !!!!
SCGt94
RE: 6.0 rough cold start.
Post by SCGt94 »
No problem, i did however send this fix to a customer with very similar issues and it took care of it. Let me know guys
Don
2002 WS6
knelson454
White puff at 100 hp
Post by knelson454 »
I'm way late reading this post. I also have the white puff come out and a wierd start up on the 100 HP setting only. If I run the tow, 60, or stock, no white smoke at all, ever. Go back to 100 HP and puff, white smoke. What was your fix for this? I'd like to get that tune. I have the '03 VXAP2, no error codes at all. Thanks.
SCGt94
RE: White puff at 100 hp
Post by SCGt94 »
k...send me a copy of your ori, the fix will be in the next revision but that might be awhile. I can write you a fix for the timing being..
Don
2002 WS6
