my u7146 and my 2004 mustang gt
Posted: Fri Jun 01, 2007 10:39 am
ok heres what
heres what i have
2004 ford mustang GT 4.6L v8 sohc
predator U7146, TWO tunes avaliable are factory hp tune and diablo tune
mods
c&l 85mm mass air meter with inlet tube and k&n filter
75mm acufab throttle body and plenum
Steeda under drive pullies
bassani 1 and 5/8ths mid length headers
bassani catless x pipe
SLP loudmouth II mufflers
ford 3.73:1 ring and pinion with trac loc rebuild kit
i have several questions.
the first question is
1. what is the difference between choosing diablo tune or factory hp tune when you can change options on each one? im not sure i understand the diffrence when the values are identical.
2. When you choose the diablo tune and then go to modify, if all you change is gearing, speed and rev limiters along with turning off the traction control will the rest of the tune still be the diablo tune?
3: regarding spark advance if i the answer to my second question is yes then would retarding the spark advance between 4000 and 7000 but leaving the values for 2000-4000 alone cause problems?
idealy id like to install the diablo tune but change the gears, speed and reve limiters and retard the spark advance two clicks to the retard position under the 4000-7000 rpm range simply because ive tried using several different fuels along with stp additives to boost the octane rating and i still detonate at high rpms in 5th gear and sometimes in lower gears at high rpms.. It is a romeo block and i know they are prone to detonation by default.
the place in Albany ny closed down so id have to drive to jersey to get a tune specific for my car, got a ball park figure on how much it would run me? i know i could just call them up but i figured im already writeting a novel here anyway i might as well ask anyway.
my last question is this
the following is a copy and paste from your site regarding ranges
what id like to know is when i choose diablo tune or factory hp tune and then choose modify are the values that show the ones that are going to be loaded or are those the current values that are in the STOCK tune.
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
heres what i have
mods
Idle (+/- 20%)
