Modify tune while NOT connected to car
Posted: Sat Aug 22, 2009 10:02 pm
by slyder
Can I connect the DSP to the wall adapter then adjust (modify) a tune while it is NOT connected to the car. Then go out and connect it to the car and install the map that I made changes too???
OR
Do I need this connected to the car 1st and then adjust the map??
-Slyder
RE: change tune while NOT connected to car
Posted: Sat Aug 22, 2009 10:06 pm
by Mike_Levy
Unfortunetly it needs to be connected. I wish it didn't. Sitting in a hot car sucks.
Same with the Trinity and making gauge setups. Would prefer to do it on the computer and then upload it to the handheld, like MSD allows.
Posted: Sun Aug 23, 2009 12:21 am
by slyder
OOPPPSS
let me re-phrase, answer may be the same
Can I go into a tune, not connected to car, change a parameter (rev limiter example) then take it and load it into the car?
again may be the same answer just phrased better.
-Slyder
Posted: Sun Aug 23, 2009 12:22 am
by Cruisin1966
No, you cannot. Something like that can only be accomplished while the Predator is connected to the car or if you have the CMR software
Posted: Sun Aug 23, 2009 12:28 am
by Mike_Levy
I actually took your first question to mean what you wrote in your second, so you really didn't have to rephrase. I knew what you meant.
