M2000 ISSUES.
PowerPuck/Extreme PowerPuck Support
mikeroot2
M2000 ISSUES.
Post by mikeroot2 »
Just installed an extreme power puck on my FL50 Freightliner 5 speed manual with a CAT3126. Engine cranks forever before starting cold. Does not want to start when warm and it tops out at 35MPH with absolutely no power. SES light(don't know what for & not going to pay to find out). If I unplug the puck and rehook factory harness the truck starts right away and runs great. Talked to tech support on phone. Hooked to correct sensors and correct plugs on puck harness. ANY suggestions, other than send it back?
RE: M2000 ISSUES.
Have you tried disconnecting the power knob from the harness to see if that changes anything?
mikeroot2
RE: M2000 ISSUES.
Post by mikeroot2 »
What if it does?
mikeroot2
RE: M2000 ISSUES.
Post by mikeroot2 »
It doesn't make a difference.
RE: M2000 ISSUES.
OK, either fill out an rma request and we'll check it out or ask the dealer you got it from if they can swap it out for you.
Mike
mikeroot2
RE: M2000 ISSUES.
Post by mikeroot2 »
Returned it and bought the Edge Products EZ. Hooked up the same way but it actually works.
Return to “PowerPuck/Extreme PowerPuck”
