U7189 part throttle shift firmness with 93octane tune.
Posted: Sat Jun 02, 2007 1:13 pm
Hi,
I have been reading about the part throttle shift firmness problems with the 87 octane tune. I am having the same problem with the 93 octane tune. The truck (2k silverado) shifts fine when driving normal but once it gets floored it then shifts VERY hard during part throttle upshifts. I also have to shut the truck off to get it to reset itself.
I find it curious that I am the only one (that i could find on the forum) having this problem with the 93 octane tune. I did originally install the 87 octane tune then went to the 93 tune. I didn't notice the problem until the 93 tune but I don't remember flooring it with the 87 tune either. The only adjustments I have done were to turn off the TM, adjusted the timing up 10% across the board and turn my idle speed up 150rpm, which oddly enough, is probably my favorite adjustment. I HATE the factory idle rpm.
Thanks for any help/suggestions on the shift firmness issue.
-Steve
**UPDATE** I restored the OEM tune then loaded the 93 octane tune again. I modified all of the setting that I mentioned above exceptfor the 3rd TM setting. I left it on and now the part throttle shift slam is gone. Even after a full throttle run. I don't notice any performance difference with it left on.
-Steve
