What are you guys plugging in the predator to get the tire size correct. I got 285-75-16 and i will plug that in and its still a little off according to my gps.
Just wanted to see what everyone else is using for their 285-75-16.
Thanks.
Tire size question
duramax07tmd
Tire size question
07 Silverado Classic 2500HD LBZ 6 Speed
Crew Cab Short Bed, LT2
-Ready Lift Leveling Kit
-285/75/16 Michelin LTX A/T 2
-5 inch Straight Pipe
-K&N Air Filter
-Diablo Predator
-K&N Air Filter
-Diablo Predator
We have not had any issues adjjsting tire size inthe new trucks.
No need for gauges unless you want to play around with the high power tunes.
If you go to the dealer, be sure to restore the stock tune to the truck and they will have no clue you ever tuned it.
Pulling fuses is not needed as long as you make sure everything in the truck is turned off when flashing.
Re: Tire size question
I started off using 270 75R16, but as the tire got worn down I had to start using 265 76R16. This was adjusted using my GPS.duramax07tmd wrote:What are you guys plugging in the predator to get the tire size correct. I got 285-75-16 and i will plug that in and its still a little off according to my gps.
Thanks.
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
