Data loging problems
Posted: Mon Jun 04, 2007 7:37 pm
by niki13
Hi,
Spoke to Mike on phone tonite and he told me to ask about my problem on the forum.
So here goes.
Having problem with cmr-dat viewer. I followed instructions from a to z about loging data to predator and getting log file from predator to dat viewer. I get transfer completed but when I try to open I always get this message .. unsupported operation attempted... I also get nothing in pid list. Mike mentionned that someonelse was having same problem and he was sent an updated version of the viewer.
I have a 2004 mustang cobra.
Any help appreciated.
Thank you.
Wayne
getting really frustrated
Posted: Tue Jun 05, 2007 7:33 pm
by niki13
Hi Mike,
Spoke to you again today. You told me to remove cmr-dat viewer from my comp and re install and everything should be ok. did it and still get same results. Can someone please help me out with this. Maybe you can send me the updated version at [email protected].
RE: getting really frustrated
Posted: Tue Jun 05, 2007 11:22 pm
Strange.
I'll ask someone to look into this tomorrow.
Are you running XP or Vista?
Re: RE: getting really frustrated
Posted: Wed Jun 06, 2007 2:32 pm
by niki13
mikel wrote:Strange.
Hi Mike,
Running XP. Thanks
Posted: Sun Jun 10, 2007 4:08 pm
by kimmer
I'm having the exact same problem, would like to see a solution for this also.
Posted: Sat Jun 16, 2007 10:06 pm
by beauwulf
I'm having a similar problem with datalogging, both streaming to a laptop and trying to load an uploaded log file into the CMR_DAT application.
U7145 - '07 Mustang GT
Western Motorsports 80mm intake tune
Dell Latitude D620 laptop running Win XP Pro SP2
standard serial cable on COM 1
When streaming, as soon as I press start I get a steady stream of error popups stating "an unsupported operation was attempted", about 10+ per second. I can't press the OK button fast enough to clear them out of the way so that I can stop recording, the only way out is to bring up Task Manager and kill the application.
If i just log to the Predator, it seems to work fine, and I can upload the log file to my laptop, but if I try to open the log file in CMR_DAT I get the stream of errors. In this case though, if I keep pressing OK on the error message, it looks like data is loading into the table, one data point per error message cleared.
Sounds like a Windows or software problem to me but I can't narrow it down - searching that error message on the web brings up way too many possibilities...
Steve
Diablo dat_viewer unsupported operation
Posted: Mon Sep 26, 2011 11:36 am
by dunlap77
Predator 7146, latest rev
I'v reloaded several times using 2 seperate PC (XP & Win 7) Everything works fine except when you go to look at the viewer. After you select the saved log it does not graph and gives you an unsupported attempt message. If you keep clicking the OK button you can see the tables appearing in the background. It may work if you clicked it 6000 times. I'm not that patient.
I tried importing the Chart file that was suggested and no help????
Any Ideas
AL
2001 Stang GT
RE: Diablo dat_viewer unsupported operation
Posted: Thu Sep 29, 2011 7:17 am
by dunlap77
Waiting for response
Posted: Thu Sep 29, 2011 10:12 am
beauwulf wrote:I'm having a similar problem with datalogging, both streaming to a laptop and trying to load an uploaded log file into the CMR_DAT application.
Steve
U7145 uses dataviewer, not CMR DAT...
Re: RE: Diablo dat_viewer unsupported operation
Posted: Thu Sep 29, 2011 10:13 am
dunlap77 wrote:Waiting for response
This is a tough one to fix as the software has been unsupported for a few years now, let me see if anyone here has some input on it.
RE: Re: RE: Diablo dat_viewer unsupported operation
Posted: Thu Sep 29, 2011 2:39 pm
by dllanod
If you download and save the log file with CMR_DAT program and then open it in data viewer, it works.
Seems strange that you must download the log file with the old software and then can only open it with the new program, but hey, it works on my U7152, 04 F250.
Posted: Thu Sep 29, 2011 2:59 pm
Uggh, I missed that.
dllanod is correct, if you can get the log uploaded to the PC, you are in good shape to use DV for playback.
Posted: Sat Oct 01, 2011 10:16 am
by dunlap77
The data viewer program worked for me on my 7146 as well. You should make that download available for the older predators when accessing the downloads. I used the 7145 to get the viewer.
Problem solved. thanks
Posted: Thu Jan 26, 2012 10:54 pm
by jclev
im going to bring up this old post because i am stuck on this as well.. was there ever a fix for this? im confused about what it says on the faq for cmr_dat.
Posted: Fri Jan 27, 2012 9:53 am
you have to upload the log to cmr dat, then you cal play it back on Dataviewer.
