Gas Question on Spark Advance adjustments ?
Posted: Tue Sep 15, 2009 2:32 am
by fadhil
how can i adjustment spark ?
RE: Gas Question on Spark Advance adjustments ?
Posted: Tue Sep 15, 2009 5:23 pm
by fadhil
can anyone tell ,e how can i adjust the spark
Posted: Tue Sep 15, 2009 11:47 pm
by SandMan817
go under "modify parameters" and go to the "SPARK" selection and then you can adjust from there.
Posted: Wed Sep 16, 2009 5:50 am
by fadhil
I mean how can I adjust rightly like more (+) or less (-)
Posted: Wed Sep 16, 2009 6:46 am
by SandMan817
im pretty sure, to the right is more spark, and to the left is less spark. Somebody please correct me if i am wrong.
Posted: Thu Sep 17, 2009 3:11 pm
by fadhil
I mean how can I adjust rightly there any analyze program or in which rate must be
Posted: Thu Sep 17, 2009 3:15 pm
If you are not sure of what to change, you should not be changing the timing....
Posted: Thu Sep 17, 2009 3:22 pm
by fadhil
can you tell me how can i change rightly there are any thing can help me like program or doc
Posted: Fri Sep 18, 2009 4:30 pm
by SandMan817
the Diablosport DataViewer program is great for analyzing your log files, if you understand what you are looking at. Also, check out DsLogReDux, it is an amazing program that automaticly goes over your log file and tells you how much to adjust your LTFT's.
Have you followed monte's tutorial?
http://www.diablosport.com/index.php?na ... opic&t=917
Posted: Fri Sep 18, 2009 5:11 pm
by neonhomer
fadhil - There is no guide or document on how to adjust it. When you adjust spark from the tool, it adjusts to a curve. The only RIGHT, PROPER way to adjust spark is to have your vehicle run on a chassis dynamometer. The technician who does the programming will know how to properly set the timing to gain the maximum amount of power for your vehicle.
Unless you know what you are doing, or are willing to risk severe engine damage to your vehicle, do not adjust the timing advance.
Posted: Fri Sep 18, 2009 7:14 pm
Well said, Neon... ;)
