some of my parameter never change.
Posted: Thu Sep 17, 2009 8:01 pm
by airdefender36905
For instance my baro always stays a 99.1 and my FAR stays at .07 on the trinity itself and on the data viewer it stay at 14.37
RE: some of my parameter never change.
Posted: Thu Sep 17, 2009 8:17 pm
not sure what the "baro" is you're talking about...
but the AFR will always be 14.xx at normal part-throttle driving.... it will only change when you go WOT...
Posted: Thu Sep 17, 2009 10:32 pm
by gizmodo
Baro is the barometric pressure. What vehicle do you have? Do you know if that is even used for your vehicle? That probably won't change a whole lot.
You are looking at commanded Fuel/Air ratio, not actual.
Re: RE: some of my parameter never change.
Posted: Fri Sep 18, 2009 12:23 pm
by airdefender36905
gizmodo wrote:Baro is the barometric pressure. What vehicle do you have? Do you know if that is even used for your vehicle? That probably won't change a whole lot.
I have a 2005 srt 4 neon. I'm trying to use my fuel/air to make sure I'm not running lean. And also how do u change tire size to fix speedo
RE: Re: RE: some of my parameter never change.
Posted: Fri Sep 18, 2009 2:30 pm
by gizmodo
You need a wideband to monitor the air/fuel ratio, you can't use commanded.
You can't change tire size in the SRT-4, you have to change the gear in the transmission.
Re: RE: Re: RE: some of my parameter never change.
Posted: Fri Sep 18, 2009 2:47 pm
gizmodo wrote:You need a wideband to monitor the air/fuel ratio, you can't use commanded.
Oh, these use a mechanical speedo?
I was wondering why we did not do tire size....makes sense.
RE: Re: RE: Re: RE: some of my parameter never change.
Posted: Fri Sep 18, 2009 2:50 pm
by airdefender36905
Oh ok makes sense. Duh. Thanks for the help
