Got it in
Posted: Thu Sep 17, 2009 8:47 pm
by 2valve
I have a 2004 mustang gt with CAI and shorty headers.
Just wondering how I should adjust spark/fuel to possibly richen my mixture a bit.. I noticed when I pulled a spark plug that it was white.
I don't have cables to hook up the predator to the PC so I can't datalog and send it right now.
What is a safe amount to adjust spark/fuel each time until it's better? Also, can the predator read a/f mixture? So I can watch it when messing with spark/fuel.
Thanks.
Josh
RE: Got it in
Posted: Fri Sep 18, 2009 8:52 am
You should only alter A/F ratios based on a wideband sensor.
Be careful with adding timing, as too much can cause problems, and keep in mind that the performance tune already has timing added.
RE: Got it in
Posted: Fri Sep 18, 2009 7:44 pm
by 2valve
A wideband sensor, but I'm N/A and lightly modded..is there sense in getting one?
I did notice when stepping on the gas I smell it a bit so maybe it's worked itself out?
Got some new spark plugs in so I guess I'll just have to change them and check them every now and then to see how they're doing. Would the 87 octane performance tune actually alter a/f ratios? I plan on going with the 93 octane tune once my tank is near empty..how would that tune effect it?
Thank you for your time and patience with me.
Josh
Re: RE: Got it in
Posted: Mon Sep 21, 2009 3:50 pm
by 2valve
2valve wrote:A wideband sensor, but I'm N/A and lightly modded..is there sense in getting one?
Josh
RE: Re: RE: Got it in
Posted: Tue Sep 22, 2009 8:56 am
by Vas@Diablosport
Regardless of being N/A or not, if you have the slightest suspicion that your vehicle is running to lean for comfort, it is definitely a good investment.
