2000 7.3 Knocks on 110 tune
Posted: Fri Sep 18, 2009 4:29 pm
by lander
My predator is 7000 I got it form The Shop hear in Lincoln Ne . It has a 9r04 update Pat said this is a 30 psi tune My truck is a 2000 f350 7.3 4 inch exhaust, afe cold air intake and wiser wheel ats 1.00 exhaust housing , big head wast gate . I have been running the 85 hp tune no problems, I tried to run the 110 yesterday and at around 19 psi is makes a knocking noise like a fuel knock I have know noise to 25psi on the 85 hp tune any suggestions thanks lance
RE: 2000 7.3 Knocks on 110 tune
Posted: Fri Sep 18, 2009 5:57 pm
by jbeasts10
Knock is normal..it is timing related.Mine does it also..No need to worry.You should be seeing roughly 28 to 32 lbs with that tune and your set-up.
Posted: Sat Sep 19, 2009 8:05 pm
by lander
Do you need a boost-fooler to get those boost number, and what did you do for your tranny
Posted: Sat Sep 19, 2009 10:50 pm
by jbeasts10
Yes ,I have a boost fooler.(I made mine..air regulator set to 21psi)..I had the tranny built..upgraded internals/Billet triple Disk Converter..Transgo Tugger kit.
Posted: Sun Sep 20, 2009 8:51 pm
by lander
thanks for the help I will work that this week
Posted: Thu Oct 01, 2009 1:38 pm
by jermort
Yep, will make some real funny diesel noises on that tune, I run the 85 for daily driving.
jammer
