When do you need a MAFia?
2002BlacknBlue
I have an 02 Harley truck, supercharged. I just put in a built engine and I also picked up a MAFia. I'm running stage 3 heads with stage 2 cams and long tube headers. My boost is right around 15#. How do I tell if I need to install the MAFia and where do I set it? I'm going for a dynotune later this week and I would like to know as much as I can before I get there. I should be putting down about 525 rwhp if that helps. I saw someone else ask when they would need a MAFia and the answer was that they didn't need one. I'm hoping for something not so generic for an answer.
RE: When do you need a MAFia?
At that power level, you'll be looking at needing a Mafia. The best way to see is log your MAF voltage and see if it hits close to 5 volts.
