05 duramax fault
Posted: Wed Jun 06, 2007 11:50 am
by beck
I have an 05 Duramax with a modified stock air box {cut an opening on side and insulated, per diesel page article.}I am using K&N OEM replacement filter.I have a MBRP 4 in. SS catback exhaust, and your U7185 programer. The first time I tried the 100 hp mode the engine hesitaded had a intake fault and had only two or three gears with the Allison. I reset to stock and AOK.
Steve
RE: 05 duramax fault
Posted: Wed Jun 06, 2007 11:52 am
What codes did the truck throw?
Have you tried any of the lower powered tunes?
Posted: Sat Jun 09, 2007 4:59 pm
by beck
Sorry, I forgot the codes ,I remember an intake fault. I have had good success with the 65 HP setting.The 100 HP episode is similar to a couple other 05 posts where the engine "pops" dies , but mine restricted full use of the tranny.
Posted: Sun Jun 10, 2007 5:21 pm
Was it a P0101? Is this a Californi vehicle?
Posted: Mon Aug 06, 2007 10:54 pm
by Unknown303
Code: P0101
Modules: ECM, PCM
Description: Mass Air Flow (MAF) Sensor Performance
Re: 05 duramax fault
Posted: Tue Aug 14, 2007 12:31 pm
by lccmo
beck wrote:I have an 05 Duramax with a modified stock air box {cut an opening on side and insulated, per diesel page article.}I am using K&N OEM replacement filter.I have a MBRP 4 in. SS catback exhaust, and your U7185 programer. The first time I tried the 100 hp mode the engine hesitaded had a intake fault and had only two or three gears with the Allison. I reset to stock and AOK.
Steve
Sounds like you limped the transmission
RE: Re: 05 duramax fault
Posted: Tue Aug 14, 2007 12:37 pm
Is this a California truck?
