Tuning after installing long tubes and cold air intake
TommyKoot
Post by TommyKoot »
Hi,
Can I also use the Predator for tuning my 2007 Z06 after installing Long tube headers, race cats and a WCC Hurricane cold air intake?
Thanks!!
RE: Tuning after installing long tubes and cold air intake
yeah.. just get your fueling dialed back in...
TommyKoot
Post by TommyKoot »
Thanks!! Does that also fix my check engine light that keeps coming on ever since I installed the WCC Hurricane intake?
Thanks again!!!
probably not... what's the trouble code?? it's probably for your rear O2 sensors cuz of the LT headers...
you'll need to get a custom tune created in order to have those trouble codes disabled...
TommyKoot
Post by TommyKoot »
It came up after installing the Air intake, a couple of weeks ago. The LT's are being installed at this moment. So it has probably something to do with air flow?... A custom tune for a Z06 is very hard to get here in Holland. Is there any change that the predator can help me with that? If so, I will order one right away!!
Thanks again!!
use the predator to scan for trouble codes, and post up what the trouble code is...
TommyKoot
Post by TommyKoot »
Ok I will. I have just ordered a Predator. Should receive it in the next couple of days. I will get back to you.
Thanks!!!
TommyKoot
Post by TommyKoot »
Hi,
Received the predator and updated it.
I will make a diagnostic run this weekend. Do I just drive for a while while the Predator is hooked up?
I know that "how to make a diagnostic run" is on this forum, can't find it ....:-) sorry........
Thanks!!
Tommy
