r17 problem Re-post
be3
r17 problem Re-post
Post by be3 »
I updated from r10 to r17 and could not start the truck after the update. After talking with tech support, I sent my PCM and u7165 in for a PCM flash and re-set the U7165. I received the PCM and U7165 today and the truck started fine. The U7165 has r14 and I can't find out any info on it. Additionally, the r17 is still on the web.
What was the problem and is the current r17 OK now? What does r14 do vs R10?
My CALID is VXCFQDA
I am Not sure if that changed when you sent the re-flash back. I could not read the vehicle when the problem occured.
This is a re-submitted post since I don't know how to move it to the top per Mike.
Thanks,
be3 (Bill Elliott)
F350 6.0 2005
RE: r17 problem Re-post
I will have one of our diesel techs chime in tomorrow with the answers you are looking for.
For future reference, to bump a thread to the top, you can simply post in that thread again and it goes right to the top.
Mike
be3
Post by be3 »
cole
Re: r17 problem Re-post
Post by cole »
be3 wrote:I updated from r10 to r17 and could not start the truck after the update. After talking with tech support, I sent my PCM and u7165 in for a PCM flash and re-set the U7165. I received the PCM and U7165 today and the truck started fine. The U7165 has r14 and I can't find out any info on it. Additionally, the r17 is still on the web.
My CALID is VXCFQDA
Thanks,
be3 (Bill Elliott)
F350 6.0 2005
There isnt an issue with r17. R17 has been tested on your PCM. As you requested wanting r14, we put r14 on the predator . And the difference between 14 and 10 is simply tune changes and calibration support.
Cole Stevens
be3
Post by be3 »
How long does it take to get a response??? I read of the great support and I don't get it!!
The response is right there?!?!?
4th post from the top....
be3
Post by be3 »
Sorry, I thought it would say answered. Should I be OK to install r17 now?
be3
Post by be3 »
I have re-installed r17 and it seems to be fine now.
Thanks,
Bill
