Custom CMR tUNE QUESTIONS?
dew1520
Post by dew1520 »
How can you tell what parameters were adjusted/changed on a custom cmr tune? I got one recently and i went to modify tunes to see what the cmr dealer changed, but everything looked like it wasnt. Like if you load a diablo stock tune without adjusting anything. I'm a little lost i thought maybe you could go through your predator to see what changes were made in a stock tune. Second if I modified some parameters in a custom tune and i press the reset all parameters key. Will it reset all the parameters back to what was in the custom tune orginally before i adjusted anything?
Cruisin1966
RE: Custom CMR tUNE QUESTIONS?
Post by Cruisin1966 »
No, there is no way without the CMR software itself to "know" what has been changed.
2007 Sublime Daytona #082/150
McKinney catch can (to be installed)
Quick
Post by Quick »
The way the Predator works is that you load/select a tune file. That's the "base" tune. Then when you go to Modify Parameters it keeps a list of the changes you make. Everything that is initially displayed is taken from the "base" tune. For example, if you go to change your fan temps it will display the current value from the tune file. If you change it, it will display the value from the Modify Parameter change list -- and there will be a "*" beside that parameter in the menu indicating that it was changed (and what is being displayed is from the change list). So a CMR tune file will show no changes. It's the "base" tune. I've never seen the CMR software so I don't even know if it would show the changes either. It might work just like the Predator in that respect and the tuner would have to keep track of changes they made or keep the tune file they started with to compare it against.
One of the main reason to get a CMR tune in the first place is that CMR can access parameters not accessible by the Predator. Torque management parameters/tables for example, so you wouldn't be able to see those with the Predator anyway.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
broadfca
Re: Custom CMR tUNE QUESTIONS?
Post by broadfca »
dew1520 wrote:How can you tell what parameters were adjusted/changed on a custom cmr tune? I got one recently and i went to modify tunes to see what the cmr dealer changed, but everything looked like it wasnt. Like if you load a diablo stock tune without adjusting anything. I'm a little lost i thought maybe you could go through your predator to see what changes were made in a stock tune. Second if I modified some parameters in a custom tune and i press the reset all parameters key. Will it reset all the parameters back to what was in the custom tune orginally before i adjusted anything?
Check this out for knowledge of how to use your Predator. Lots of good info here.
http://www.case-enterprises.com/xeryder ... edator.htm
"El Magnifico" 2009 Challenger SRT8 AutoStick, Corsa Sport Catback Exhaust, Trinity 91 Modified Tune, 180 T-stat, Moroso Catch Can, DMH Electronic Cut Outs, ProTorque Billet Stator 3200 RPM High Stall Torque Converter, K&N, BFG 295/40/20w Rear Tires
