1-4 shift (CAGS)
vettefun
1-4 shift (CAGS)
Post by vettefun »
I installed the performance tune and the 1-4 shift is still there. I thought that was deleted in the performance tune. How do I get rid of it.
Was just doing some reading online. Apparently you need to go into adjustable parameters to turn it off. Is that correct. I also looked in the manual and I don't see where in the manual to do this. No mention of CAGS in parameters anywhere. Where exactly do I make the changes.
U7198 predator, 1999 corvette. New predator with 2.13 version.
RE: 1-4 shift (CAGS)
Select tune it>select the tune>modify tune>modify parameters>select CAGS>set to 'off'>press escape until the tool asks if you would like to install the tune>select yes.
