Page 1 of 3
DSLogRedux vs. COT Protection
Posted: Sat Oct 17, 2009 11:50 am
by Grumpy_Aero_Guy
We are looking at logs where, in some instances, during WOT, the COT kicks in and it craters the WOT AFR.
We are working to update the code to handle this and to provide better AFR WOT adjustment.
This will require and additional mandatory parameter to log (Cat Temp).
This improved code is in the works. Not sure of an ETA.
Certainly before TCM support is released.
RE: DSLogRedux vs. COT Protection
Posted: Sat Oct 17, 2009 12:18 pm
yep, the new mandatory/required parameters that will have to be logged are:
Catalyst Temperature Bank 1 Sensor 1
Catalyst Temperature Bank 2 Sensor 1
Re: DSLogRedux vs. COT Protection
Posted: Sat Oct 17, 2009 7:25 pm
by Poetique
Grumpy_Aero_Guy wrote:We are looking at logs where, in some instances, during WOT, the COT kicks in and it craters the WOT AFR.
How depressing.
But not nearly as depressing as my presently useless Predator... been too busy to call in and get a force restore code. Wish they we're open like an hour longer lol. I generally have a non-busy gap between 5-6:00, but I'm central time >_<
RE: Re: DSLogRedux vs. COT Protection
Posted: Sat Oct 17, 2009 7:38 pm
can't call during lunch break??
Posted: Sat Oct 17, 2009 7:40 pm
we are looking for people to send us WOT data logs that we can use to test with...
so, if you all could please do a good WOT log and send it to us at [email protected], that would be awesome!
you need to log the same parameters you normally do, but now you also need to log:
Thanks!!
Posted: Sat Oct 17, 2009 7:50 pm
by Poetique
It's not a work thing, it's a me being near my truck thing. Working is only a problem on Tuesdays.
I generally don't even get to see my truck till around 4:30. I could probably get to it at some other point during the day, but if I have to wait 20 minutes to get someone on the phone I won't have time to do anything with the Predator.
That's why I made the comment in the other thread about wishing they made a universal force restore code... In fact, for the next update guys, please implement this, it is utterly annoying having to call to get the code >_< I figure it's probably done to prevent people from screwing things up, but a simple notice saying doing it will void the warranty should suffice (which is irrelevant in my case because my predator is a month out of warranty anyway).
For that matter I'd very much prefer being able to update my Predator without having to restore the original backup in the first place...
Also I'll send yall a log as soon as (if) my Predator quits making an ass of itself, lol.
Posted: Sat Oct 17, 2009 9:08 pm
cool man, thanks... I hear ya...
Posted: Sun Oct 18, 2009 10:40 am
bump
Posted: Sun Oct 18, 2009 7:32 pm
by 05Z71
I don't have that parameter...
Posted: Sun Oct 18, 2009 8:20 pm
I don't believe you... hahahaha...
when going to log the data, you don't have Catalyst Temperature Bank 1 Sensor 1 or Catalyst Temperature Bank 2 Sensor 1 available as a selectable parameter??
did you try the GM Complete list??
did you try using your laptop and the dataviewer, and seeing if they're available via the dataviewer??
you have an 05 truck - those parameters HAVE to be availalble for you to log...
I know they're in there...
Posted: Mon Oct 19, 2009 12:13 am
by 05Z71
Gotta check it Lew, but I know for sure they are not in the Predator itself. I will pull the laptop out when I am off Tuesday-Friday and see what it be lookin like.
Posted: Mon Oct 19, 2009 12:33 am
by joeyz71
wow, even if the COT is maxed out it still dumps extra gas?
Posted: Mon Oct 19, 2009 9:50 am
no...if you disable the COT cuz you have no CAT's, by maxing out the temp, it will not dump in extra fuel...
Posted: Mon Oct 19, 2009 11:52 pm
by bsmithaert1
I'll send you 1 tomorrow.
Posted: Mon Oct 19, 2009 11:53 pm
by bsmithaert1
Do you want COT disabled or left alone?
