U7198 Adding timing to Performance Tune
rv85
Post by rv85 »
I wanted to increase my 02Corvette Z06 timing ( performance tune installed) about 1-3% .See any problems?
Thanx
rv85
RE: U7198 Adding timing to Performance Tune
well, you need to monitor the knock retard... if you get any KR, you'll need to back off the timing...
fwiw, all the custom tunes I've done for vettes, I usually end up having to reduce/pull out timing due to KR already present with the diablo performance tunes, since they jack up the timing pretty good compared to the stock tune...
