Digital Gauge - RPM min/max not working...
on the digital gauges, it has the min/max values underneath the live readout...
for engine speed (rpm), it's not working... the min/max is always at 0 / 9000 rpm... it doesn't change at all...
my car doesn't even go up to 9000 rpm... heh...
RE: Digital Gauge - RPM min/max not working...
engine speed is a standard gauge that will always be 0-9000 rpm, at least the way it sits right now.
but how come the other gauges show the min/max values from your live readings, and they change when a new min/max value is hit... but the rpm one does not??
Cause they are not RPM gauges?
Its pretty simple....rpm gauges are generally used for a known/given range, thus it can be pre scaled. A min/max feature would be cool for a tach though, at least a Max....
Return to “Trinity GM Gas”
