U7137 OUT OF MEMORY ISSUE FIX/2010 HEMI Ram support added
Posted: Mon Nov 23, 2009 1:42 pm
by johan
The crom below has the "out of memory" issue resolved as well as 2010 support added into it, if anyone currently have the out of memory issue please update to this and let us know.
http://www.diablosport.com/downloads/pr ... xport.crom
RE: U7137 OUT OF MEMORY ISSUE FIX/2010 HEMI Ram support adde
Posted: Wed Nov 25, 2009 4:01 pm
by Drdred
Will this also help the rev issues in the 07-08's?
Posted: Wed Nov 25, 2009 6:19 pm
by johan
Define rev issues?
We did not address anything in the older calibrations, if we did i would of mentioned it.
Re: U7137 OUT OF MEMORY ISSUE FIX/2010 HEMI Ram support adde
Posted: Thu Nov 26, 2009 3:38 pm
by bonza
johan wrote:The crom below has the "out of memory" issue resolved as well as 2010 support added into it, if anyone currently have the out of memory issue please update to this and let us know.
Thanks for the update, it fixed the out of memory issues that where occuring when using the datalog function.
Verhicle: Dodge Ram 2009
calid: 68059438ab
Posted: Sun Dec 13, 2009 9:52 pm
by butch1581
Fixed my data logging issue too, now just need the MDS smoothed out!
Posted: Tue Dec 22, 2009 8:45 pm
by ROADRAMBLERNJ
To upgrade the crom I need to return to stock tune and reset the tool. I cannot do this. When I choose this option, the tool displays "Unable to restore original backup" When i click on "More Info" it says "PCM: error unlock for reflash (-1). What gives and how do I correct this?
Posted: Wed Dec 23, 2009 11:42 am
ROADRAMBLERNJ wrote:To upgrade the crom I need to return to stock tune and reset the tool. I cannot do this. When I choose this option, the tool displays "Unable to restore original backup" When i click on "More Info" it says "PCM: error unlock for reflash (-1). What gives and how do I correct this?
Use the Legacy connect instructions on the dsdl and update it without auto connect...
Posted: Wed Jan 06, 2010 9:21 pm
by ROADRAMBLERNJ
I did like you said mikel. I'm in a catch 22 here. Tool won't accept the new 9t06d_export.crom because I haven't returned the vehicle to stock tune. I can't do that because when I try, it gives me the "PCM: error unlock for reflash (-1). Am I doing something wrong? I need some help here. I have to go back to the dealer for service and I can't show up with a custom tune installed. Please advise a.s.a.p.
Posted: Thu Jan 07, 2010 11:03 am
Use the Legacy connect option onthe DSDownloader, this way, it will not know you have a backup inthe tool, and it will allow you to update it. Then you can restore the backup once the new crom is on there.
Posted: Thu Jan 07, 2010 4:54 pm
by ROADRAMBLERNJ
OK, it worked. Didn't know not to power up the predator until AFTER picking the 9t06d_export.crom as the file to load into the tool. Was able to load original factory tune back onto truck. I guess RTFM is true. Thanks for the help. Ed.
Posted: Thu Jan 07, 2010 4:57 pm
by ROADRAMBLERNJ
PS: Can I now (after trip to the dealer) upgrade to the 9r06 CROM without losing any of the benefit of the 9t06d_export.crom ?
Posted: Thu Jan 07, 2010 5:08 pm
Yes, they are basically the same.
