Cured ping issue on 09 Ram Hemi!!!
Posted: Wed Dec 02, 2009 2:23 am
by M15
All I did was add more fuel. 7.5% to be exact. No more ping and it pulls alot harder now too!
RE: Cured ping issue on 09 Ram Hemi!!!
Posted: Wed Dec 02, 2009 12:10 pm
by FAhemiST
wow, that seems like a lot of fuel. where in the rpm range did you need it?
Posted: Wed Dec 02, 2009 12:48 pm
Good move. 7.5% is not a lot of fuel to add...
Posted: Wed Dec 02, 2009 9:30 pm
by M15
Thanks. I added fuel to all rpms. And Mikel is right,Its not a lot more fuel. Havent even noticed a difference in fuel consumtion yet. Hey Mikel any estimate to where my air/fuel ratio is at? Ideally I would like to be between 12.5:1 to 12.9:1 Thanks.
Re: Cured ping issue on 09 Ram Hemi!!!
Posted: Thu Dec 03, 2009 12:52 am
by 09Laramie
M15 wrote:All I did was add more fuel. 7.5% to be exact. No more ping and it pulls alot harder now too!
good info- is that on the 93 tune or the 87?
RE: Re: Cured ping issue on 09 Ram Hemi!!!
Posted: Thu Dec 03, 2009 2:13 am
by M15
Its on the 93 tune with 2 degrees taken out cause I only can get 91 pump gas here.
Re: RE: Cured ping issue on 09 Ram Hemi!!!
Posted: Thu Dec 03, 2009 10:57 am
M15 wrote:Thanks. I added fuel to all rpms. And Mikel is right,Its not a lot more fuel. Havent even noticed a difference in fuel consumtion yet. Hey Mikel any estimate to where my air/fuel ratio is at? Ideally I would like to be between 12.5:1 to 12.9:1 Thanks.
We usually set the tunes in the low 12:1 range, and with the extra fuel you're prolly close to 12:1 at WOT.
We have dyno'd as many HEMIs as anyone, and have found they do not like to make best power in the high 12s, thus we tune them for about 12.3:1.
Mike
RE: Re: RE: Cured ping issue on 09 Ram Hemi!!!
Posted: Fri Dec 04, 2009 12:11 am
by sbarbs
Sounds good. I just loaded the 93 tune myself. I added 5% fuel as well. Still some pinging. I registered at the highest 4Degrees S-T knock. Not to bad. It seems it happens the most when pulling hard in a higher gear and stomping on the throttle in a down shift. Anyone else with this problem? I'm gonna try adding more fuel as well. I have 93 octane in it with an octane additive as well. I suspect it should be at least 95-97 octane.
Posted: Fri Dec 04, 2009 1:16 am
by M15
If your going to use octane booster I highly recomend Lucas octane booster. I had 1.5 bottles in my tank when racing and never pingged once. And that was without adding any fuel on the programmer.
Posted: Fri Dec 04, 2009 6:48 pm
by concoursd
4 degrees is not bad, especially at higher load (lugging) situations. hemis are just really sensitive.
Posted: Fri Dec 04, 2009 11:58 pm
by sbarbs
I am using Lucas additive. I'm gonna try adding a little more fuel to all RPM's and possibly pulling a little timing. Hopefully that will do the trick.
Posted: Thu Dec 24, 2009 12:28 pm
by mauri_oreilly
hey how you do the 93 tune with 2 degrees taken out ???
and how you add more fuel. 7.5%????
could you explain me because im new on this
thanks.
Posted: Mon Jan 18, 2010 6:06 pm
by hjanaya
same questions pretty new to this.. how do you add 7.5% more fuel? is it the throttle calibration?
Posted: Tue Jan 19, 2010 7:57 am
by DGatzby1
um, was thinking; 93 Octane tune - 2 degrees of timing = 91 Octane tune ??
Glad you found the right combination for your car....but some math for discussion!
Posted: Thu Jan 21, 2010 5:03 pm
by Oosik
M15 ended up selling the tuner, the knock came back. He mentions it on dodgeforums.com
