Transmission Temp
Posted: Fri Dec 04, 2009 2:18 am
by butch1581
What PID is this called? I selected the one that says "TRANS TEMP? but it just stays at 40 all the time, there must be another one somewhere? Thanks
RE: Transmission Temp
Posted: Fri Dec 04, 2009 10:03 am
by jimb
Are you refering to "J1850 TRANS OIL TEMP" on the J1850 node in DV? Please record a log with the PID (about 5 seconds worth is sufficient) and runtime.txt found in My Documents\Dataviewer. Either postup or email it to [email protected]
Re: Transmission Temp
Posted: Tue Dec 16, 2014 8:25 am
by tresbien
Tried to check the transmission temp on my 300c srt8 2006 today using the "J1850 TRANS OIL TEMP" PID. Same thing happened to me. Showed -40C and didn't change as the engine got warmer.
Transmission Temp
Posted: Sun Jun 04, 2017 8:03 am
by RichardGhval
у меня по коробке пишет такую вещь
1 Fault Found:
17095 - Transmission Fluid Temp Sensor G93: Implausible Signal
P0711 - 35-10 - - - Intermittent
что этото и как с этим боротся
