trouble code module block not programmed
duckslayer
Post by duckslayer »
I have a problem on my 2005 Dodge Ram 3500, I have had the predator since the truck only had 2000 miles it now has 47,000 it, It keeps saying control module not programmed unless I go back to the regular program. I just started having this problem after having my exhaust manifold replaced at a dealer. ANY IDEAS? :( s/n 000177 p/n U7130 Version V.9r03
injectionperf
RE: trouble code module block not programmed
Post by injectionperf »
what is the code?
duckslayer
It says control module not programmed no numbers, That is why I need help, It should show a code number, This is under permanent codes, either I don't know where to look or there is not one. Any help would be appreciated!
duckslayer
Okay, This is what I did since I never got any help. I reprogrammed my predator with the newest version out and then put in the preformance tune and it worked so far no problems, I have also loaded the 200 hp and will try it, since I am doublre stacked, I will turn my one off and see what difference it makes, then turn on the other 120hp and see how they work together, My 1000 hp tranny is just about done, just incase. :)
