05 Vette, 06 LS4, 05-06 GTO , 06 TBSS , 05-06 SSR added!
Thats right, all the applications previously supported by our U7191 Predator are now included in the latest Trinity U7194_update crom.
Enjoy!
RE: 05 Vette, 06 LS4, 05-06 GTO , 06 TBSS , 05-06 SSR added!
WOOHOO!!!!
since I don't see it on the Trinity download page yet, here's the file for anyone that needs it...
trinity_u7194-1r06d_update.crom
(1013.1 KiB) Downloaded 1143 times
Stone2500
Post by Stone2500 »
I have an 05 GTO and the Trinity doesn't work on it. When will an update be available?
Should be today...
Stone2500 wrote:I have an 05 GTO and the Trinity doesn't work on it. When will an update be available?
new update sent.
Stone2500
Post by Stone2500 »
New update same problem. Not supported by Trinity. When can I expect to see an update that works?
here's the new incremental update:
http://diablosport.com/index.php?name=P ... ic&t=20896
you have to make sure your trinity is on the 1r07 revision update first, before applying that new update...
Stone2500
Post by Stone2500 »
Installed update. 2005 GTO still not supported. Were the calids for the GTO addressed in the update?
well, what were your Cal ID's?? I don't see them posted anywhere...
Stone2500
Post by Stone2500 »
I emailed them to general support 11 days ago and Mike last week. I just sent them to the address listed above [email protected]
k thanks... I got your tune file you sent...
I forwarded it to johan to check out...
johan checked it out, your cal ids ARE in the update...
after you updated the Trinity to the new update, did you go back into the trinity and then re-select your vehicle???
after an update, you have to go into the trinity menus and re-select your vehicle before it will actually update itself and load the new crom revision update info...
WoodburyMan
Post by WoodburyMan »
'05 GTO works fine for me :)
Welcome neighbor Woodburyman!!!!
Return to “Trinity GM Gas”
