Page 1 of 2
2005 Neon SRT-4 U7134 Question
Posted: Wed Dec 16, 2009 10:05 pm
by Philth
I last had the DSP when it was on crom v11. Back then, the S3 PCM would not respond properly to any commands I uploaded from the DSP. Specifically, the cooling fans would cause problems. For instance, when I changed the fans to come on at 185*, the fans would not come on until the stock temp activation of 206*, but then they wouldn't shut off at all once on. So, the PCM was seeing something different, but it just wasn't performing the change properly. I also experienced no responses at all to timing at fuel changes for the WOT tables as well.
Also, the performance 93 tune netted me an instant 13.2 AFR across the board during WOT.
Does anybody know if this has been fixed? I would like to buy it again and give it a try, but the above problems were a little alarming.
RE: 2005 Neon SRT-4 U7134 Question
Posted: Thu Dec 17, 2009 11:05 am
Odd, I have never seen or heard of another S3 car with this issue....
I owuld say even if there is a problem, it can easily be solved via a few emailed custom tunes...
Posted: Thu Dec 17, 2009 3:32 pm
by Philth
Sorry, I just realized I posted this in the Trinity section. Can move if you wish.
Who would I contact regarding the custom tunes?
Posted: Fri Dec 18, 2009 12:18 pm
by SCGt94
that would me me...send me your original backup, ill take care of ya. This is the first time i am hearing about a S3 having cooling fan issues. I also had a similar problem with a PT cruiser however i havent heard back if what i did fixed it.
Posted: Fri Jan 22, 2010 11:51 pm
by hussler
im having a problem with my S2 not taking the tunes
Posted: Sat Jan 23, 2010 10:32 am
by gizmodo
What do you mean? Are you saying the flash says it has completed, but nothing has changed or are you getting an error when trying to flash?
Posted: Sun Jan 24, 2010 12:58 am
by hussler
yea it says that tune is complete but my fans dont come on when i set the for 185 and the boost wont go more then 15lbs which is spring pressure! i can max the boost controller out with the trinity and still only see 15lbs.
Posted: Sun Jan 24, 2010 3:45 pm
by gizmodo
Are you running PCM controlled boost, or do you have some other type of setup? If you aren't on PCM controlled (EBC, MBC, WGA bleed etc) changing boost with the programmer won't get you anything.
Don can better answer the fan question. I know some people have reported having this issue with the staged PCMs.
Posted: Mon Jan 25, 2010 8:24 pm
by hussler
i am running pcm controlled boost
Posted: Tue Jan 26, 2010 9:25 am
by gizmodo
Are you talking about the spike, or what it is holding at redline? If you are talking what it is holding, the stock turbo won't do much more than 15-16 psi.
Posted: Tue Jan 26, 2010 4:25 pm
by hussler
i am big turbo and its not a spike it goes to 15 and stays there till i let up! im using a trinity tho
Posted: Tue Jan 26, 2010 10:23 pm
by gizmodo
PCM controlled boost on a big turbo is a whole new animal. Do you have a CMR tune? I certainly hope so. The 93 octane tune won't work for your setup.
Posted: Wed Jan 27, 2010 10:06 pm
by hussler
yea its a CMR tune
Posted: Thu Jan 28, 2010 10:24 am
by gizmodo
Who did it? You need to work with your tuner.
Posted: Thu Jan 28, 2010 11:26 pm
by hussler
i have been working with him! but when ever he messes with the timing talbe is when i cant boost more then spring pressure but if he leaves the timing talbe stock then it will boost like its suppose to!
