new preditor dead
wmorris4x4
new preditor dead
u7135 started to update car after downloading updates, got a flash from unit and smoke , now cant download, i have 2 others with no problem this is a new unit right out of the box.
RE: new preditor dead
See if the dealer will swap it out. Otherwise you'll have to RMA it.
I'm wondering about quality control lately. We've been hearing about this issue quite a bit in the past 6 or so months, and I'd never heard of it before then. DS employees, Are these assembled by hand or done by machine? Whats changed in the past 6 months to a year? The Trinity was released, but was anything changed in the Predators?
wmorris4x4
Re: RE: new preditor dead
i have 2 others an they work fine, set this one up just like them an a flash then smoke . i didnt know they was having problems with them latelyMike_Levy wrote:See if the dealer will swap it out. Otherwise you'll have to RMA it.
RE: Re: RE: new preditor dead
happened to me back in March. Send the unit back and get a replacement. Do you have an 05 LX? If so use the 9r12 firmware version...not the 9r18 or the 9r20. Only use the later firmware if you have like an 08 LX or newer.
Suxs that it happened, but you vehicle should not be damaged.
05 Mag RT AWD
AFE Stg II CAI
Magnaflow C/B
JBA High Flow Cats
Edelbrock Shortys
SLP 25% Underdrive Pulley
Ported Throttle Body
Jet 180 T-stat
Tune by Johan
BT Catch-Can
AFE Stg II CAI
Magnaflow C/B
JBA High Flow Cats
Edelbrock Shortys
Jet 180 T-stat
Tune by Johan
BT Catch-Can
