U7192 issues
Posted: Sat Dec 26, 2009 6:38 pm
by flyin6
U7192
GM06 2.05
2007 Hummer H2 SUT
I have several issues with this predator. I purchased the thing a couple years ago and installed a 87 octane, then later a performance tune.
First of all, I noticed it never could adjust the shift firmness at all, no big deal, but it should be able to do that.
Recently, I installed electric fans, stock GM stuff that connects to the PCM via a Nelson Performance cable.
Well, I tried in a variety of ways to get a tune for my Predator to activate pin #42.
That's when we started dealing with a communication problem between my predator and my laptop. To put it simply, the predator will not recognize being hooked up to the laptop or visa-versa. I am using the Diablo supplied serial to USB cable, and have tried now, I believe every driver known to man, but still no luck.
So the way I am looking at this, I think I need to start all over with a new predator. This unit obviously does not work properly, and I want to begin adjusting injector slope and other things since I have added many bolt-ons to the vehicle.
Basically, I need to either get predator smart with a functional unit, or move on to something much more capable, which I would prefer not to do.
So, folks can you help?Could I trade for a newer unit or trade/purchase?
I know we can get this thing to work if I can only get the predator to function properly.
Thanks!
RE: U7192 issues
Posted: Sat Dec 26, 2009 10:46 pm
by steeleshark2
Which windows version? Do you have dsdownloader?
Re: RE: U7192 issues
Posted: Sun Dec 27, 2009 10:00 am
by flyin6
steeleshark2 wrote:Which windows version? Do you have dsdownloader?
Laptop has XP Media edition
Version 2002, service pack 3
DS Downloader? What's that?
RE: Re: RE: U7192 issues
Posted: Sun Dec 27, 2009 11:10 am
by Ill_Born_SS
Ok, first off you have an old unit.
Here is what it could do, http://www.diablosport.com/index.php?mo ... ay&pid=135
As for the activation of pin42 for the fans, no you can`t do it with the predator, you need to get the boyz at diablo to activate it in a tweek, they would need a copy of your original tune to do so, but with the older model ?
There is an update program in place, http://www.diablosport.com/index.php?na ... ic&t=10946
Re: RE: Re: RE: U7192 issues
Posted: Sun Dec 27, 2009 2:34 pm
by flyin6
Ill_Born_SS wrote:Ok, first off you have an old unit.
Copy all. Thanks for the info.
Looking at the RMA info, I'm in trouble again. It says to expect 30 days to get the unit back! I'm on break from Afghanistan, I don't have time like that. I guess I'm just cooked!!!!!!!!!
I'd ship it out tomorrow if it could be turned around quickly, but it doesn't look like that is the case, normally...
RE: Re: RE: Re: RE: U7192 issues
Posted: Sun Dec 27, 2009 8:32 pm
by Grumpy_Aero_Guy
Call them tomorrow, explain the situation..I find it hard to believe they wouldn't try tp help you, given the circumstance. I assume you're in the military. If so, thank you for all you do....
Re: RE: Re: RE: Re: RE: U7192 issues
Posted: Mon Dec 28, 2009 9:04 am
by flyin6
Grumpy_Aero_Guy wrote:Call them tomorrow, explain the situation..I find it hard to believe they wouldn't try tp help you, given the circumstance. I assume you're in the military. If so, thank you for all you do....
OK,
I'll call them, see if they can do anything.
You're welcome! But, I'm no longer military, already retired after a full career. I still do exactly the same thing I used to do, a helicopter pilot, except now as a contractor. The combat forces over there, counting guys inside and outside of the wire are about evenly split between uniform wearing guys, and we contractors. In some unusual cases we actually see more combat than our brothers. I have been in Afghanistan now since early 2006, flown thousands of combat and combat support sories.
Thanks all the same, we're all on the same team!!!
RE: Re: RE: Re: RE: Re: RE: U7192 issues
Posted: Tue Dec 29, 2009 9:28 am
by flyin6
Just fixed the problem...I purchased a new Predator!
When I get it I''ll start the process here to get the proram modified with pin #42 activated
Can't wait, should be fun!
Posted: Tue Dec 29, 2009 10:00 am
by Grumpy_Aero_Guy
well, I guess that's ONE solution..... LOL...
Posted: Tue Dec 29, 2009 10:12 am
by bsmithaert1
First, Thank you for your service. I had my U7193 upgraded and turnaround was about 2 weeks. Maybe you can get it done and recoup some of the cost of the new unit.
