dodge dealer
smokindodge
dodge dealer
they say that smarty is the only one not able to see by the dealer but i saw on here that the daiblo is to.can someone verfiy this plase. thanks.
RE: dodge dealer
I assume you mean the dealer being able to view that the factory tune has been changed to the performance tune? I always flash my car back to stock if I have to take the car in for more than just an oil change.
RE: dodge dealer
The Predator will install your stock tune back to the vehicle at any time.
Bullydog also does not erase keystrokes or fuel consumption.Kasey wrote:But it will clear your key counts, right?
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
Honestly...I'm not exactly sure. Since I'm new to this it is what the folks at Mads Electronics (Smarty) are saying. The Smarty evidently does not clear key counts (which is also where they say the dealer will look first??) and that the Predator does. Mostly I've seen this info on www.cumminsforum.com posted by a guy named Bob Wagner who apparently works for Mads. Maybe someone else on here knows exactly what they're talking about and can chime in?????johan wrote:When you say "key counts" what are you referring to?
Yeah if someone could provide us with some more info i have no issues looking into this, we have all the factory tools here so i just need to know what to check for so i can verify.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Yep...just found that out. Didn't know it was something that simple...duh. So is this something that the Predator does? If so, can this be fixed to where it does not. I know this is what the folks at Smarty say makes there's the best as far as undetectability...ch2037 wrote:Key Counts- how many times the trucks keys have been turned on. Almost all programers reset this # when you go back to stock. Then the stealership sees only a few counts & knows you did something to the truck. Instead of showing ,say, 267 it shows 9.
But also...doesn't it clear this number when you or the dealer clear a code too?
This is a c/p how the competitor words one of the updates, related to Key Cycles:V2.2.5a Feb, 2006
Customer Downloader
Ford New Part Number VXDB1xx.HEX 2005 Excursion
Fixed Multiple Vehicle Part Lock
Dodge New Flash 253253X.XAE 2005
New Flash 203252X.XAI 2004
Resolved Erasing of Key Cycles, and Fuel Used
Recalibrated 2004.5-2005.5 Vehicles
New Feature 2005 Vehicle Options Available!
: Idle Up Enable
: Auto Door Lock/Unlock Enable
: Set Headlamp Delay Time
Customer Downloader
: Idle Up Enable
