2007 jeep srt8
malik
2007 jeep srt8
Post by malik »
My car is Jeep srt8 hemi 6.1 L... i bought U7135 with the usb interface but i need to know what to do and what is the most effective tune for my car?
Do i have to change the thermostate by modified one?
Please i need your help
concoursd
RE: 2007 jeep srt8
Post by concoursd »
get a catch can installed and if you want a 180 degree thermostat
concoursd
RE: 2007 jeep srt8
Post by concoursd »
I also forgot to mention to clean out your intake manifold of the oil puddle that is probably in there. The oil will drip into your cylinder and cause spark knock. The catch can recommended will resolve any further oil from getting sucked into the intake manifold.
malik
RE: 2007 jeep srt8
Post by malik »
Thank you so much....
how about the tune? i need to know what is the most effective tune to my car and how is the custom tuning?
concoursd
RE: 2007 jeep srt8
Post by concoursd »
In general, you want to get your knock to as close to zero as possible. As mentioned before, each car has its own needs and therefore, do some datalogging with the predator and fine tuning of the fuel and timing can be used to maximize the full throttle performance. All of this stuff should be done AFTER you have cleaned up the intake manifold and fixed the oil issues with a catch can. The oil will cause knock so if you try tweaking the predator tunes before cleaning up the oil and such, then you will be chasing your tail.
Return to “General Support”
