torque converter question
SandMan817
Post by SandMan817 »
I am planning on purchasing a 2600 stall torque converter next week. My main question is, will i run into any problems after i install it? Since the converter will be slipping more than stock, will the computer throw a code and start adjusting pressures? I was talking to my teacher and he was saying that the tcm controls the shift pressures and shift scheduling. ANy info would be a big help
2002 GMC Sierra Ext Cab 5.3(LM7)
RE: torque converter question
you'll need to get a custom tune created to have changes made for the new/different converter...
SandMan817
what type of changes would be made if i got a custom tune? People on FSC have said that i wouldnt run into any problems after putting the higher stall tcc on but tthey could be wrong.
not sure exactly... mikel or johan from diablo could tell ya more...
SandMan817
alright monte ill wait for one of them to chime in on this subject.
SandMan817
bump for mod to look into
You may want to raise the stall speed MPH a bit, other than that, it should be fine.
SandMan817
what do you mean the stall speed mph? sorry i am not really understanding what you are saying.
you asked what changes would be made in a custom tune for a TC....the common change most people make is to raise the lockup speed of the converter to avoid lugging on the highway.
SandMan817
my current lockup is around 40 or 45mph. The engine drops down to a pretty low rpm but it isnt lugging it or anything. Would i be fine not having this adjusted?
Yup.
