Tire and Gear Adjustment in U7151
Posted: Thu Jan 07, 2010 1:28 pm
As you will all notice on the newest revision for U7151(9r08) there are a few new adjustable parameters in the Axle Ratio section. I will give you a breakdown of each here.
Enable Gear/Tire change - Anytime you need to adjust gears/tires or NOV you must set this parameter to enable. If not, the PCM will not use the values entered and refer to another area of the calibration. Anytime you enable gear/tire change you need to check the following three parameters listed to ensure they are correct. The default settings may not be the same as what is in the vehicle.
Axle Ratio - This is the gear ratio of your drive axle.
Tire Revs Per Mile - This is the number of revolutions your tire will make in one mile. This value can usually be found on the website of your tire manufacturer under the specifications for your particular tire. That is the best resource for this info as tires rarely meet the exact size that is on the sidewall. If you can't find the info anywhere then you will need to calculate the circumference of your tires based on the sidwall info and divide that number into a mile. There is a Tire diameter calculator stickied in this section, here's a link http://www.diablosport.com/index.php?na ... ic&t=15724
Once you have the diameter you need to calculate your circumference.
Circumference = Pi X Diameter where Pi = 3.1415926
Now that you have the circumference you can divide that into 63360 which is how many inches are in a mile. The outcome is your Tire Revs Per Mile.
NOV Adjust - This value represents eNgine speed Over Vehicle speed when the vehicle is in direct drive(OD off/3rd gear in a 04-08 F150) with the torque converter locked. The easy way to calculate this is using the following equation.
Tire Revs Per Mile x Axle Ratio divided by 60 = NOV
This parameter is used in some calibrations for transmission shift tables and is affected more with large changes in gears and tires.
