2009 Mustang V6 Problem
I just got my U7145 Predator for my 2009 V6 Mustang, but I went to initially setup the but it doesn't recognize when I take the ignition to on to get the original backup to be saved to the predator. Please help
RE: 2009 Mustang V6 Problem
Contact the distributor you got it from and ask them to swap it out.
So it is just a bad programmer?
sounds like it...
Well I just got my new programmer and tried to hook it up again, but I still had the same problem. I tested the OBDII connection and it failed. I don't know what else to do? It keeps saying I might have a performance tune, but all I have done to it is dual exhaust and cold air intake. Please help
Try having it reflashed at ford, that way we KNOW it is a stock tune...
So finally was able to get it into ford today to reflash, come home and i get the same error message and failed OBA II connection test I got previously
check your fuses.
ive seen sometimes a blown fuse will cause the OBDII port not to work.
