2008 Ford F250 King Ranch 6.4L- unable to change tire size
Andysapp
Post by Andysapp »
Hi. I have a 2008 Ford King Ranch F250 with 20" tires and have installed 17" winter tires (winter tires are not available in original size). I have tried changing the tire size several different ways (even reverting back to the original tune and going to 900 revs down to 550 revs) and the Predator U7164 shows the change but the speedometer error doesn't change at all. I have even downloaded the latest crom with no change. You did indicate that the problem may be that the Predator isn't writing to the ABS module. Any idea when I might be able to look at my speedometer and see the right speed?
unit 1: 8U7A-14C204-CF
unit 2: 7U7A-14C337-AB
email [email protected].
Thanks, Andy.
SCGt94
RE: 2008 Ford F250 King Ranch 6.4L- unable to change tire si
Post by SCGt94 »
The abs module controls tire size changes which we don't flash. It can be done by other means until i get a chance to finally look at this. Does the truck have traction control? if it doesn't i can make a custom that has your tire size, if it does then it will be permanently off while the custom tune is in.
Don
2002 WS6
Andysapp
Post by Andysapp »
Hi. Thanks for the reply. The truck is a 4x4 but as far as I know it doesn't have traction control. If it helps I use the 80 HP tune for the fuel mileage.
The tires on it now are 265/70R17 down from the 285/65R20.
Thanks, Andy
2008 Ford King Ranch F250 4X4 diesel.
SCGt94
Post by SCGt94 »
andy, who is the manufacturer of the tires themselves
Don
2002 WS6
Andysapp
Post by Andysapp »
SCGt94 wrote:andy, who is the manufacturer of the tires themselves
Hi Don: The current tires are Firestone Winterforce P265/70R17. The originals were what came with the truck from the factory. B.F Goodrich I believe. Hope this helps.
Thanks, Andy.
SCGt94
Post by SCGt94 »
yea thats perfect, ill get back to you later today with a tune for ya
Don
2002 WS6
Andysapp
Post by Andysapp »
Hi Don: My Firestone tires are rated at 668 RPM.
Just wondering if you are working on a general tire size fix or if you response got lost?
Thx, Andy.
SCGt94
Post by SCGt94 »
Working on a general fix as of right now, having some trouble getting my hands on a truck though.
I got a file i am emailing you right now..
Don
2002 WS6
Andysapp
Post by Andysapp »
SCGt94 wrote:Working on a general fix as of right now, having some trouble getting my hands on a truck though.
Yes I got the file. Question. Since this is a FRD file rather than a CROM do I reinstall the original back up, load this one as a custom tune & install? Or do I install it over the current 80hp tune?
Thx, Andy.
SCGt94
Post by SCGt94 »
you can just load this file to the tool then load it to the truck. That frd has the two ori's already in it. So just connect it to the pc open dsdownloader and hit send tune file to tool. Remember this tune WILL kill your traction control if it is on your truck that is. It will cause the t/c off button to stay illuminated.
Don
2002 WS6
Andysapp
Post by Andysapp »
Sorry Don. I installed the tune. No difference re speedometer output. I tried a couple of different tire sizes but the error remains the same. If you have an updated CROM file that might work I am willing to give it a try.
Thx, Andy.
SCGt94
Post by SCGt94 »
o rly? hmm interesting. Did you install the custom tune with all your adjustable params untouched?
Don
2002 WS6
Andysapp
Post by Andysapp »
Transferred the tune to the predator. Installed as custom (shown as extreme) with no changes. Applied changes after to see if there was any difference. Same results each time. Note: I just overwrote the 80 hp tune already on the truck.
Andysapp
Post by Andysapp »
An update to the custom tune you sent me:
Pros: love the fact I can actually write to the TCM. Fuel mileage appears to be better. Lots of power & nice response.
Cons: Unable to change tire size (no difference). In cold weather I had major surge issues twice coming down to idle (it revved up a fair bit before going back to idle). Once it hit DPF regen cycle it never got out. tremendous amount of power but unable to reach the temperatures needed to burn off. Essentially went into regen every day and stayed there all day long. Last one I went through nearly two tanks of fuel in regen before I gave up. Switched back to Ford original and it burned off in very short time ( I could smell and feel the difference in heat output).
Conclusion: Excellent response, good fuel mileage but lousy in regen & no change in speedometer response. Please, please include the ability to write to the TCM in the next tune.
Thx, Andy.
SCGt94
Post by SCGt94 »
andy, the 6.4 has always written the tcm :)
thank you for the feedback, i made progress on the tire size issue only to be slammed by 6.0 and 4.7 stuff that needs to be tested and get out.
Don
2002 WS6
