2010 Camaro SS LS3
dwebster
2010 Camaro SS LS3
Post by dwebster »
What is the latest update? How do I update my predator if needed?
RE: 2010 Camaro SS LS3
what revision is it on now?
is it all working fine?? if so, then no need to update...
"if it ain't broke, don't fix it"
flynnaz
Post by flynnaz »
Does the newest Diablosports software version work with the newest update from GM? I just ordered a Predator for my 2010 Camaro SS, the dealer updated all my systems software last month, will I be good to go?
you should be... but if GM came out with some new calibration update at that point when they did it, then you may have to post up a copy of your original backup tune file so that diablosport can add support for the new calibration in a new update...
however, I haven't seen anyone else have an issue with anything in the past few months with a GM update, so you should be good to go man...
RedJewel2SS
Re: RE: 2010 Camaro SS LS3
Post by RedJewel2SS »
flynnaz wrote:Does the newest Diablosports software version work with the newest update from GM? I just ordered a Predator for my 2010 Camaro SS, the dealer updated all my systems software last month, will I be good to go?
the latest revision for the predator and trinity works with the latest GM update.
steeleshark2
Post by steeleshark2 »
You need R14 beta in the Predator if it was updated last month. The link to download is here:
http://www.diablosport.com/index.php?na ... ic&t=19753
Make sure you have the USB interface kit so you can connect the Predator to the computer.
2010 Camaro SS
Transformers Edition
DIABLEW PREDATOR TUNED
Muffler Delete
Volant CAI
flynnaz
Post by flynnaz »
What does the R14 beta have that would change anything for me? Also does the CAGS on/off work for 2010 Camaros? It says vetts only?
do you have your predator yet? what revision is it on? were you able to install and adjust the diablo tunes??
the latest production release crom revision update file is u7194-9r13.crom which is the same as the r14 test beta file...
if you're predator is already on 9r13, then no need to change...
flynnaz
Post by flynnaz »
Thank you, I have my Predator u7194, it is Ver 9r13. I had two options for tunes, I live in AZ where the gas is 91oct. I picked 91oct tune, I thought there was a CAI 91oct tune for it like on my 2009 Charger Predator.
steeleshark2
Wonderful thing about the Predator is you are not restricted to a certain tune. When adding a CAI you just need to get fuel trims dialed in and WOT fuel corrected. This will give you the most out of the cai. If you even feel more froggy you can get Lew to do a custom tune for ya and he will get all that and more dialed in for you. Check this thread for do it yourself:
http://www.diablosport.com/index.php?na ... opic&t=917
Check this for a custom tune:
http://www.dslogredux.com/DiabLew_Tune/
2010 Camaro SS
Muffler Delete
Volant CAI
flynnaz wrote:Thank you, I have my Predator u7194, it is Ver 9r13. I had two options for tunes, I live in AZ where the gas is 91oct. I picked 91oct tune, I thought there was a CAI 91oct tune for it like on my 2009 Charger Predator.
no, GM's don't need special setups like the Fords and Dodges do...
GM's will have the Diablo Tune - which is made for 93 octane gas, and then the 91 octane tune...
as for the CAI, do like Steele said above ^ ^ ^ ^ and do some data logs and get your fueling dialed in using the info at that link he posted...
the Fords and Dodges can't adjust the fueling like that, like we can for GM's, that's why they need CAI-specific tunes in them...
