U7190 error required time delay has not expired
Posted: Fri Jan 29, 2010 1:46 am
by hellz
2003 Hummer H2
yes it is a old tuner, that i just bought new
i want to say that it has backed up my stock tune, and it shows my VIN # on the predator.
when trying to install teh performance tune tho, i get 2 errors
Required time delay has not expired
scripted error
write failed.
yes i have the onstar and radio fueses pulled
key turned on, not accesories
i have even unplugged teh battery in a attempt to see if it would clear it so i could upload.
now what??
besides the obvious of getting a new updated unit.
RE: U7190 error required time delay has not expired
Posted: Fri Jan 29, 2010 8:16 am
by 06MonteSS
do you have any other aftermarket items installed in the truck, like aftermarket remote start, alarm, satellite radio, trailer brake, stereo amp, in-dash nav system, etc etc??
you need to also disable/disconnect any of those types of items as well, since they create power draws...
Posted: Fri Jan 29, 2010 9:43 am
those are usually voltage related errors...
Posted: Fri Jan 29, 2010 4:54 pm
by hellz
well it turns out i havent actually gotten the onstar fuse pulled.
i folled the instructions in the manual, and pulled a few more additional fuses, but it seems the Onstar fuse is actually the fuse labled "Info" int he fuse box. so, when i get off work tonight ill give it a try and hopefully we can call this good.
thanks for the help btw...
