Air,fuel mixture
steve128h
Air,fuel mixture
Post by steve128h »
I have a predator tune that I use on my Charger 08. I have been using the Data Viewer 3.2 to track performance. I am wondering if there is a way that i can see the percentage of the Air,fuel mixture? I here you can see it on a dyno, but not sure if its possible with the predator. Please help.
Thank you,
gizmodo
RE: Air,fuel mixture
Post by gizmodo »
Unfortunately not, you will need to install a wideband O2 sensor.
steve128h
Post by steve128h »
how do I get a wideband 02 sensor, and how does it install? is it something I can install?
brandy16
Post by brandy16 »
I have a 2006 300c and I can see air fuel ratio when I data log I don't know why you would not be able to. Do a data log and make sure you select A/F when you are selecting what you want to monitor. You will find AFR under fuel.
bighemitex
Post by bighemitex »
when i log that pid it does nothing, it shows up on dataviewer but there is no variation and that can't possibly be correct. steve128h, you can order a wideband system online or buy from your local speed shop. I have a Innovate LC1 and db gauge. i haven't installed it yet but it was recommended to me even though without another module it only logs AFR against time. alot of guys like zeitronix and wideband commander by dyno jet.
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
Quick
Post by Quick »
The A/F parameter that the Predator can log is "commanded" afr. For a stock engine it should be pretty close. As soon as you add physical modifications it can diverge from actual afr.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
bighemitex
Re: RE: Air,fuel mixture
Quick wrote:The A/F parameter that the Predator can log is "commanded" afr. For a stock engine it should be pretty close. As soon as you add physical modifications it can diverge from actual afr.
after a while does it go back to 14.7 after adding mods?
gizmodo
RE: Re: RE: Air,fuel mixture
Post by gizmodo »
It isn't adaptive, if that's what you're asking. It will always command the same thing, regardless of your mods.
Quick
Post by Quick »
Well, yes. Well within 6 seconds of closed loop operation I believe. Due to the feedback from the narrowbands. But that's the actual AFR in closed loop operation. The commanded afr is a calculated model and many assumptions (constants) are made based on the physical characteristics of the stock engine. In open loop operation the adaptives are a smaller contributor to your AFR.
Now that you mention it, I'm not positive that the "commanded" afr takes into account the fuel trim adjustment. I think it does but I'm not sure.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
duster360
Post by duster360 »
Quick wrote:Now that you mention it, I'm not positive that the "commanded" afr takes into account the fuel trim adjustment. I think it does but I'm not sure.
It does not. Chrysler PCMs command a stoich A/F of 14.38 during closed loop. The stock narrow band 02 of course pulls it up to ~14.7 through the Long/Short Term Fuel Trim.
