Predator Custom Tune
ffrja
Post by ffrja »
I have a 2007 GMC Sierra Classic 2500HD 6.6L Duramax LBZ with a gutted Cat and 4" MagnaFlo Cat back exhaust. I have a Predator U7186 Revision 9r08. Since gutting the cat I have been getting P0401 on the 65 hp setting but no code as of yet on the 85 hp setting. I have installed an EGR blocker plate and get the code on all HP settings. Is it possible to get a "Custom Tune" that will eliminate the codes for the insufficiant flow caused by the blocker but still have the functionality of the programmer as it stands? If it is, can you give me the details of cost and procedure?
RE: Predator Custom Tune
Have you looked into the finger stick?
ffrja
Post by ffrja »
Yes, I just wanted to see if there were other options available through programming first. If I can avoid cutting into my harness that would be preferable.
2007 GMC Sierra Classic 2500HD CC 6.6L Duramax LBZ, Gutted Cat and 4" MagnaFlo Cat back exhaust. "A" Pillar Guage Pod with Boost and Pyro. Predator U7186 Revision 9r08
No, we cant provide any tunes to disable any emissions equipment....
rydnhi4x4
Re: RE: Predator Custom Tune
Post by rydnhi4x4 »
ffrja wrote:Yes, I just wanted to see if there were other options available through programming first. If I can avoid cutting into my harness that would be preferable.
I felt the same way when I did this modification. Was really nervous cutting into that harness. After you do it the wires are very easy to conceal and the Dealership will never notice unless they cut into that wiring harness.
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
ffrja
RE: Re: RE: Predator Custom Tune
Post by ffrja »
Fingerstick is on its way. Thanks Guys!
